Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 2m 20d Gender: Male Location: Vic Posted 24/07/10 12:20 AM Share Posted 24/07/10 12:20 AM I wish u were in vic.Solution 2.Purchase stock leafsSwap them overSell me lowered onesSee how front sitsRepeat process if front is to low. Link to comment https://www.fordxr6turbo.com/forum/topic/69573-raising-a-lowered-bfmk2-ute/page/2/#findComment-1027160 Share on other sites More sharing options...
hardcore Member 92 Member For: 17y 1m 24d Gender: Male Posted 13/08/10 11:39 PM Author Share Posted 13/08/10 11:39 PM Took car in today for a wheel allignment, but apparently its too low to fit on the machine. Anyone else been told this? Can I go elsewhere or will I have this issue everywhere? Link to comment https://www.fordxr6turbo.com/forum/topic/69573-raising-a-lowered-bfmk2-ute/page/2/#findComment-1032469 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 2d Gender: Male Location: SW Sydney Posted 14/08/10 12:59 AM Share Posted 14/08/10 12:59 AM You'd be best off going to a suspension specialist for the alignment - they should be able to fit the car on their hoist Link to comment https://www.fordxr6turbo.com/forum/topic/69573-raising-a-lowered-bfmk2-ute/page/2/#findComment-1032481 Share on other sites More sharing options...
hardcore Member 92 Member For: 17y 1m 24d Gender: Male Posted 14/08/10 07:05 AM Author Share Posted 14/08/10 07:05 AM Stick yr head under the rear-if you can get under there, or a mirror-pinch the misses little make up compact mirror.If you have lowering blocks you will see them between the axel tube and leaf springs where they meet. The springs are clamped to the axel tube directly, so if there is a metal block, about 50mm square? in between the two then you have blocks.Here are some pics can someone tell from these what has been done? or do I need better pics?Added one to show height off exhaust Link to comment https://www.fordxr6turbo.com/forum/topic/69573-raising-a-lowered-bfmk2-ute/page/2/#findComment-1032531 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 2d Gender: Male Location: SW Sydney Posted 14/08/10 07:49 AM Share Posted 14/08/10 07:49 AM Your springs have been re-set, you will need to get them re-set back to factory or swap them as suggested with someone looking for lowered springs.You should change the front springs too, otherwise the nose will be pointing to the ground Link to comment https://www.fordxr6turbo.com/forum/topic/69573-raising-a-lowered-bfmk2-ute/page/2/#findComment-1032538 Share on other sites More sharing options...
hardcore Member 92 Member For: 17y 1m 24d Gender: Male Posted 05/04/11 11:06 AM Author Share Posted 05/04/11 11:06 AM Hi Guys,I know this is an old topic, Does anyone know if there are any guides for leaf spring replacement? similar to the front suspension one which has been done? I got some standard fronts and rears. Quoted $450 to raise at local pedders. Link to comment https://www.fordxr6turbo.com/forum/topic/69573-raising-a-lowered-bfmk2-ute/page/2/#findComment-1094679 Share on other sites More sharing options...
Emosh99 Member 260 Member For: 14y 5m 21d Gender: Male Location: Melb Posted 04/08/11 04:41 AM Share Posted 04/08/11 04:41 AM Can someone explain what 'resetting' means? Link to comment https://www.fordxr6turbo.com/forum/topic/69573-raising-a-lowered-bfmk2-ute/page/2/#findComment-1129629 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 2m 20d Gender: Male Location: Vic Posted 04/08/11 05:16 AM Share Posted 04/08/11 05:16 AM Heating the leaf springs and setting them to a new height. Basically making them less curved. Normally they add an extra leaf too. Link to comment https://www.fordxr6turbo.com/forum/topic/69573-raising-a-lowered-bfmk2-ute/page/2/#findComment-1129636 Share on other sites More sharing options...
Emosh99 Member 260 Member For: 14y 5m 21d Gender: Male Location: Melb Posted 04/08/11 07:10 AM Share Posted 04/08/11 07:10 AM is that a good option and how much can I expect to pay for that? Link to comment https://www.fordxr6turbo.com/forum/topic/69573-raising-a-lowered-bfmk2-ute/page/2/#findComment-1129678 Share on other sites More sharing options...
