  • Member For: 16y 6m 17d
Posted (edited)
Gday guys,
Got a light ticking coming from the turbz. Its an Ba MKII XR6T ute.
Only happens when I accelerate. Not at idle or just rolling. Any ideas on what it could be?
Dont think its loose turbo bolts as I just had them tightened.
Cheers
EDIT: Comes from the engine bay btw
Edited by Jeshua
  • A much better forum
  • Legacy Donating Member
  • Member For: 18y 2m 8d
Posted
Injectors???
Posted
Could be the injectors... Forgot to mention one thing which is quite weird. If I say, put my foot flat in 5th gear doing 50 and the car very slowly accelerates it doesnt hapeen.
Exhaust manifold is all good.
cheers
Posted (edited)
Dont think its pinging. Not quite the same sound, engine temperature is normal, isnt high engine temperature a symptom of pinging?
Might post a video when I get the car back, just in to get a paint touch up.
If all else fails its to the mechanic.
Cheers again guys
Edited by RHR
No need to quote above post. USE FAST REPLY
  • Member For: 20y 11m 12d
Posted
Is it coming from the driver's side? Has your car had a custom tune? Possibly the Boost Solenoid????
Posted
I reckon your on the money mate. Happened a couple weeks after tune. Also explains why it doesn't happen in real low rpm cos it's not
under boost.
Cheers for the help lads.
Posted
under boost.
Oh by the way... Expensive fix? Possible DIY job?
  • Talks Cheap, Let's Race
  • Member For: 19y 10m 16d
Posted
My boost solenoid was ticking from just turning the key to the on position, a trip back to the tuners fixed it.
