May 11, 201016 yr #1 my a/c fan unit squeaks, only on low. It is driving me freakin crazy What do I need to do/use to get rid of this problem?? Take fan unit out and oil it? Or are they a bearing unit? Please help before my steel cap boots deal with it
May 11, 201016 yr #2 I have the same prob, passenger side, and yes it drives you nuts!! it happened when I first got it, so I sprayed silicon spray into it, worked but wouldnt reccomend it as you gotta guess where it is and stinks for days when the fans going.
May 11, 201016 yr #3 I had the same problem until I read this, http://www.fordxr6turbo.com/forum/index.php?showtopic=66881&st=0&p=990843&hl=air+con+fan&fromsearch=1#entry990843
May 11, 201016 yr #4 Author Yeah I had a look at it..seems that forum has two issues going on though..to solve the ticking noise I gather you stretch the springs...but to stop the squeeky I need to use engine oil to lubricate it instead of a silicone oil..right?
May 11, 201016 yr #5 yeah I had the squeaky noise, and I used engine oil, but I put the hole fan unit out and oiled it up, and no squeak's its been 3 weeks, silicone spray only lasts like a week.
May 11, 201016 yr #6 Author Wait...what did you do? put a hole in the fan unit itself and filled it with oil???
May 15, 201016 yr #10 Author argh couldnt get the fan off....however I took off the plastic cover and then took the metal bottom off the motor and oiled the cup that the shaft sits in...hope it works....although I am suprised there is no bearing on the bottom. It sure does heat up when the fan is on...
