15/03/10 10:48 AM15/03/10 10:48 AM #1 any help on this would be great what im trying to do, is there a way to remove the metal ring and boot, from the grey plastic bottom without damaging it? I dont really wanan hack it up, if I can get away with it
15/03/10 11:41 AM15/03/10 11:41 AM #2 The ring slides up from the plastic part. There are some small tabs underneath that you have to push in. I used a flat blade screwdriver. It does take some force because it is a tight fit. From memory there are 4-5 tab's but once you get a couple unclipped it comes out easy. If your still struggling I can take some pictures tomorrow.
15/03/10 04:36 PM15/03/10 04:36 PM #3 The top metal ring should just come off as well. Yet again probably needs reasonable force, mine was replaced recently with a new gearknob and that included the metal flare that sits atop the leather boot.
16/03/10 12:08 AM16/03/10 12:08 AM #4 Author thanks for the reply guys, that's what I figured, but I didn't wanna go snapping the bottom if they are just there for looks. much apprecaited
