  • Member For: 17y 2m 26d
Posted
Hi Guys,
Just wondering if anyone can help, I have had a new rear bar put into my car but the reverse sensors weren't replaced which I dont mind but the issue is when in reverse I get a constant beep.
Just wondering if there is a fuse that I can remove in order to stop the beep.
Cheers
  • Member For: 18y 8m 2d
Posted
Have a quick read of your owners manual, I think you can use the stero volume control when the car is turned off to adjust the sound - just turn it right down.
Posted
Hmm interesting will have a look when I get the chance, I thought it would be a fuse that I can pull out.
  • Member For: 17y 2m 16d
Posted
In mine, I can adjust the volume. It's a setting in the menu. Look around in the menu and you'll find it :)
  • 2 months later...
Posted
Does anyone have an answer for this as I have looked everywhere, read the manual etc but cannot find anyway to shut the constant beep. Is there a fuse or anything like that I need to remove.
It so annoying.
  • Sucker
  • Moderating Team
  • Member For: 22y 4m 23d
Posted
What model is your car? If FG there's an option to adjust the volume (but not off), but your best bet would be getting it removed if it's not hooked up.
  • Member For: 18y 8m 27d
Posted
Or seek retribution on the beeper itself....pretty useless those reverse sensor options even when they do work as designed. Better off without all that cr*p.
But not as bad as the early nineties 626/TX5's that would beep/chime UNENDINGLY if the driver's side door was open ie if you were sitting somewhere just listening to the radio. Revenge is sweet.
Posted
If nobody knows how to shut these sensors up, where is the unit so that I can rip it out? Its sending me nuts...
