zzz-ba ute Member 69 Member For: 15y 10m 8d Gender: Not Telling Posted 11/01/10 10:17 AM Share Posted 11/01/10 10:17 AM hey guys I know there are write ups butI am looking to put a full turbo engine inthe ute (not convert the na engine to turbo)just wondering what I'll need, any advicethings I don't want to hear"buy a t""sell it buy a t""why don't you buy a t""cheaper to buy a t" I have spent $11,000 modifying this ute alreadygearbox, diff, suspension,p.s im starting tomorrow so please helpI have $5,000 engine is costing 3,000help Link to comment https://www.fordxr6turbo.com/forum/topic/65021-engine-conversion/ Share on other sites More sharing options...
BensXR6T Member 478 Member For: 16y 6m 1d Gender: Male Location: Burpengary QLD Posted 11/01/10 10:58 AM Share Posted 11/01/10 10:58 AM (edited) Should be a fairly simple straight swap. You will probably need to get it towed to a tuner if you haven't got the ECU and BEM from the original car.If you have put a high flow cat on there, the standard tune from the original ECU will also chuck a hissy fit, also needing a tow to a tuner.If you don't have a tuner in mind yet, I would suggest you get to know one before going ahead with the swap over.Best of luck.Cheers,Ben Edited 11/01/10 10:59 AM by BensXR6T Link to comment https://www.fordxr6turbo.com/forum/topic/65021-engine-conversion/#findComment-969903 Share on other sites More sharing options...
zzz-ba ute Member 69 Member For: 15y 10m 8d Gender: Not Telling Posted 11/01/10 11:04 AM Author Share Posted 11/01/10 11:04 AM (edited) awesome thanks mate, its a ba so the cat problem shouldn't exist.on other threads here I am led to believethat there is only a second o2 sensor after the cat on bf's wich causes the problemalso if I get the computers from the orig carcan I just get ford to sort it out as I don't havea flash tuner yetand if I don't get the orig computers can ford sort it? Edited 11/01/10 11:06 AM by zzz-ba ute Link to comment https://www.fordxr6turbo.com/forum/topic/65021-engine-conversion/#findComment-969907 Share on other sites More sharing options...
zzz-ba ute Member 69 Member For: 15y 10m 8d Gender: Not Telling Posted 11/01/10 12:13 PM Author Share Posted 11/01/10 12:13 PM in less than 24 hours the old engine should be outand the new one nestled in.so what do I have to do.I think I know its just I don't want to finish it and be told I forgot to change on random bolt somewhere and have to pul the engine again Link to comment https://www.fordxr6turbo.com/forum/topic/65021-engine-conversion/#findComment-969941 Share on other sites More sharing options...
zzz-ba ute Member 69 Member For: 15y 10m 8d Gender: Not Telling Posted 11/01/10 12:36 PM Author Share Posted 11/01/10 12:36 PM whats gotta happen with the wiring loomif I can avoid pulling it out and swappingit to the turbo one I would be happy as a wit a Link to comment https://www.fordxr6turbo.com/forum/topic/65021-engine-conversion/#findComment-969947 Share on other sites More sharing options...
BensXR6T Member 478 Member For: 16y 6m 1d Gender: Male Location: Burpengary QLD Posted 14/01/10 08:00 AM Share Posted 14/01/10 08:00 AM Ford can sort out the issues I'm pretty sure. most of the wiring should be there as long as it's the same trans but there wont be anywhere to plug the wire for the butterflies in the plenum as the turbos dont have them. The loom for this should just unplug behind the air box Link to comment https://www.fordxr6turbo.com/forum/topic/65021-engine-conversion/#findComment-970806 Share on other sites More sharing options...
zzz-ba ute Member 69 Member For: 15y 10m 8d Gender: Not Telling Posted 19/01/10 09:59 AM Author Share Posted 19/01/10 09:59 AM IT'S ALL DONEHopefully, it goes to ford tomorrow to get the computers to talk and be friends, other than that pretty straight foward. it took a little longer than expected as there where too many smoke breaks and ducking out to grab this and that Link to comment https://www.fordxr6turbo.com/forum/topic/65021-engine-conversion/#findComment-972532 Share on other sites More sharing options...
zzz-ba ute Member 69 Member For: 15y 10m 8d Gender: Not Telling Posted 20/01/10 11:52 AM Author Share Posted 20/01/10 11:52 AM ok this is where the problems begintook it to ford and they said everythingwas fine, they programmed in the new computerand it wouldn't start. they ran a diagnosticand no fault codes came up. they reset the computerand tried again for three hours finally a fault code came up for a communicationfailI think I need to wire in a wastegate solenoidand a boost pressure sensor to the pcm so itwill stop having a cryhad the car running twice on carby cleaner, then when the airlock was out it ran for a couple of seconds anddied. everything else is finecar turns overany advice would be a big help Link to comment https://www.fordxr6turbo.com/forum/topic/65021-engine-conversion/#findComment-972932 Share on other sites More sharing options...
zzz-ba ute Member 69 Member For: 15y 10m 8d Gender: Not Telling Posted 20/03/10 07:44 AM Author Share Posted 20/03/10 07:44 AM ok it's been back on the road for a while everythingis running sweet. once I got the pcm sorted out it turned out to be a really simple conversionthings needed: xr6 turbo engine with engine wiring harness intercooler and pipping ( I went with all aftermarket) turbo exhaust boost controller ( I went with turbotech manual boost controller) boost gauge flash tuner (tell c.a.p.a what you have done and they'll send you a tune that works)things not needed: xr6t pcm a trip to ford boost pressure sensor wastegate control solenoid any part of the xr6t car wiring harnessthe only wiring I had to do:because I bought a non ute engine I had to wire one of the plugs of the gearbox into the harnessthe utes have a third plug on the gearbox harness that from what I could tell the sedans don'tso all I did was follow the wires it spliced into on the original harness and followed then to the pins on the plug next to the pcm. then I cut them and spliced them into the correct wires on the new harness. Link to comment https://www.fordxr6turbo.com/forum/topic/65021-engine-conversion/#findComment-992885 Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 10m 2d Gender: Male Location: Southern Highlands NSW Posted 21/03/10 01:25 AM Share Posted 21/03/10 01:25 AM Link to comment https://www.fordxr6turbo.com/forum/topic/65021-engine-conversion/#findComment-993013 Share on other sites More sharing options...
