Engine Conversion
Featured Replies
#1
hey guys I know there are write ups but
I am looking to put a full turbo engine in
the ute (not convert the na engine to turbo)
just wondering what I'll need, any advice
things I don't want to hear
"buy a t"
"sell it buy a t"
"why don't you buy a t"
"cheaper to buy a t" :biggrin:
I have spent $11,000 modifying this ute already
gearbox, diff, suspension,
p.s im starting tomorrow so please help
I have $5,000 engine is costing 3,000
help
#2
Should be a fairly simple straight swap. You will probably need to get it towed to a tuner if you haven't got the ECU and BEM from the original car.
If you have put a high flow cat on there, the standard tune from the original ECU will also chuck a hissy fit, also needing a tow to a tuner.
If you don't have a tuner in mind yet, I would suggest you get to know one before going ahead with the swap over.
Best of luck.
Cheers,
Ben
Edited by BensXR6T
#3
  • Author
awesome thanks mate, its a ba so the
cat problem shouldn't exist.
on other threads here I am led to believe
that there is only a second o2 sensor after
the cat on bf's wich causes the problem
also if I get the computers from the orig car
can I just get ford to sort it out as I don't have
a flash tuner yet
and if I don't get the orig computers can ford sort it?
Edited by zzz-ba ute
#4
  • Author
in less than 24 hours the old engine should be out
and the new one nestled in.
so what do I have to do.
I think I know its just I don't want to
finish it and be told I forgot to change on
random bolt somewhere and have to pul the engine again
#5
  • Author
whats gotta happen with the wiring loom
if I can avoid pulling it out and swapping
it to the turbo one I would be happy as a
:spoton: wit a :donut:
#6
Ford can sort out the issues I'm pretty sure. most of the wiring should be there as long as it's the same trans but there wont be anywhere to plug the wire for the butterflies in the plenum as the turbos dont have them. The loom for this should just unplug behind the air box
#7
  • Author
IT'S ALL DONE
Hopefully, it goes to ford tomorrow to get the
computers to talk and be friends, other than
that pretty straight foward. it took a little
longer than expected as there where too many smoke
breaks and ducking out to grab this and that
#8
  • Author
ok this is where the problems begin
took it to ford and they said everything
was fine, they programmed in the new computer
and it wouldn't start. they ran a diagnostic
and no fault codes came up. they reset the computer
and tried again for three hours
finally a fault code came up for a communication
fail
I think I need to wire in a wastegate solenoid
and a boost pressure sensor to the pcm so it
will stop having a cry
had the car running twice on carby cleaner, then when the
airlock was out it ran for a couple of seconds and
died. everything else is fine
car turns over
any advice would be a big help
  • 1 month later...
#9
  • Author
ok it's been back on the road for a while everything
is running sweet. once I got the pcm sorted out it
turned out to be a really simple conversion
things needed: xr6 turbo engine with engine wiring harness
intercooler and pipping ( I went with all aftermarket)
turbo exhaust
boost controller ( I went with turbotech manual boost controller)
boost gauge
flash tuner (tell c.a.p.a what you have done and they'll send you a tune that works)
things not needed: xr6t pcm
a trip to ford
wastegate control solenoid
any part of the xr6t car wiring harness
the only wiring I had to do:
because I bought a non ute engine I had to wire one of the plugs of the gearbox into the harness
the utes have a third plug on the gearbox harness that from what I could tell the sedans don't
so all I did was follow the wires it spliced into on the original harness and followed then to the pins on the plug next to the pcm. then I cut them and spliced them into the correct wires on the new harness.
#10
:thumbsup:
Recently Browsing 0
