December 27, 200916 yr #1 Hi guys I am looking at the process west stg1 cooler and want to know what max power level I can run it to before the intake temps start gettin too high.I like to keep the standard look so im not after any stage 2 opinions. I am also looking at the hyperflow 100mm thick cooler which is also a stage 1. I am after peoples own experiences with the stage 1 coolers, actual results would be fantastic too.thanks
December 28, 200916 yr #3 I am only running just shy off 300kw so I don't have any experience of max power, but I do know that after 4 power runs very little power had been lost due to heat soak.PW Stage 1 one's in my experience are an easy to fit, well made piece of kit that performs really well. just wish I had the cash for a stage 3.
December 29, 200916 yr #4 I ran 325rwkw on 15psi with the stage 1 cooler... Has plenty more in it... Only thing that stopped me was the standard crossover, so upgraded to the plenum which meant an upgrade to the stage 2 cooler to fit the new pipework
December 29, 200916 yr #5 I have a hyperflow stage 1 cooler, the car is making 334 rwkw at 14 psi. If you want your car to look standard you better get the black one. Also they say it's a direct replacement for the original cooler but I cut out about 15 mm of metal to get the hyperflow cooler to fit.
December 29, 200916 yr #6 stage 1 on my car, 300rwkw, no sign of power drops. very nice piece of gear.
December 29, 200916 yr #7 Author the process west is lookin better everytime. Last thing I want is to cut anything on my new car Edited December 29, 200916 yr by tonyv
December 29, 200916 yr #8 Author just a little off topic while im here, will the standard exhaust on my bf flow enough power for 340rwkw if the cat is a 100 cell cat? Or am I better off going decat Edited December 29, 200916 yr by tonyv
December 29, 200916 yr #9 I changed the exhayst on my bf and got a 45rwkw gain dont know why you would not do it, it seemed like good value for money
