vetha Member 61 Member For: 18y 7m 14d Gender: Male Location: Melb, VIC Posted 24/11/09 11:31 AM Posted 24/11/09 11:31 AM ahhhh I just opened my bonnet and saw pink stuff pouring out of the coolant reservoir im hundred percent sure its transmission oil what do I do??thanks samson
JETURBO ...JD TUNING ADELAIDE... Legacy Donating Member 23,708 Member For: 18y 3m 20d Gender: Male Location: Adelaide Posted 24/11/09 11:37 AM Posted 24/11/09 11:37 AM boost it to 10psi for at least 30min or rip a huge skid
vetha Member 61 Member For: 18y 7m 14d Gender: Male Location: Melb, VIC Posted 24/11/09 11:51 AM Author Posted 24/11/09 11:51 AM ????
JETURBO ...JD TUNING ADELAIDE... Legacy Donating Member 23,708 Member For: 18y 3m 20d Gender: Male Location: Adelaide Posted 24/11/09 11:54 AM Posted 24/11/09 11:54 AM well what? not a good answer?stop driving it asap if its not damaged(the trans)get it a trans flush yes flush not service might beable to save your trans and ull need a new radiator and then an aftermarket trans cooler asap after or u could still rip a skid and see what happens?
tab Sucker Moderating Team 32,303 Member For: 22y 4m 26d Gender: Male Location: Brisbane Posted 24/11/09 12:02 PM Posted 24/11/09 12:02 PM What he's trying to say is you potentially have a busted heat exchanger in the radiator. If that is the case you'll most likely have coolant in your transmission oil as well.So don't drive it (not even to rip a big skid) and get it looked at asap.PS: Jet, given this is posted under NA...might be a bit hard to give it 10 pounds
vetha Member 61 Member For: 18y 7m 14d Gender: Male Location: Melb, VIC Posted 24/11/09 12:13 PM Author Posted 24/11/09 12:13 PM aight thanks guys
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Legacy Donating Member 1,808 Member For: 17y 9m 4d Gender: Male Posted 24/11/09 07:30 PM Posted 24/11/09 07:30 PM is this a common problem? which gearboxes does this mostly affect?
tab Sucker Moderating Team 32,303 Member For: 22y 4m 26d Gender: Male Location: Brisbane Posted 25/11/09 12:13 AM Posted 25/11/09 12:13 AM Wouldn't say common, but has happened to quite a few of the earlier BAs. From memory they changed the radiators at some point which would hopefully have stopped it.Here's an old thread but I'm sure there's a few more around.
