  • Member For: 19y 7m 3d
Posted (edited)
Hey guys I think my windscreen water pump on my bf ute shat itself (no water,no noise). Where is the pump located and is it easily accessible. Cheers in advance.
Edited by alpha
  • Legacy Donating Member
  • Member For: 22y 7m 22d
Posted
Left front guard under where you fill it up.
Bit of a PIA to get it out. I would check fuses first.
Posted (edited)
Hey Zap thanks.. just checked the fuse.. all ok. Will pm you for details regarding getting into the pump as I have no idea.
Do I need to take the front wheel off to remove the guard?
Edited by tab
quote removed
  • Sucker
  • Moderating Team
  • Member For: 22y 5m 11d
Posted
Just turn the steering full-lock to the right and it might give you enough clearance...but do that with the engine running or you could get air in the power steering lines.
Posted
So that everyone knows how it is done. Here is a document Ford produced earlier.
501-16 Wipers And Washers.pdf
