ASNU Member 261 Member For: 23y 8m 5d Location: Brooklyn Posted 22/09/03 10:41 PM Posted 22/09/03 10:41 PM This is what has happened to my diff after towing a duel axil trailer on the weekend.Ford has put only a 8mm locating bolt under the diff houseing that holds all the leaf springs together.At some stage after towing on the weekend the left hand 8mm bolt has totally sheared off inside the leaf springs and caused my diff to move back about 1 inch on the left hand side causeing the steering wheel to go off centre plus as you could imagine not steering that well.All the bushes have been chopped out as well so some good aftermarket ones will be put in so it does not happen again.I suggest to all you ute guys and girls get underneath your utes and make sure your 8mm bolt is dead centre in the hole underneath your diff houseing or the same thing will happen to you.I am going to modify in the future the size of the bolt as 8mm is just ridicules if your carrieing loads or giving your T abit of herbs.Hard to describe the discussed feeling I have about the poor engineering put into this rear end set up.Such a good car with a little bolt fitted causeing problems.
Cobra potty trained Legacy Donating Member 1,938 Member For: 23y 5m 6d Gender: Male Posted 24/09/03 01:50 AM Posted 24/09/03 01:50 AM thanks mate ... take a look tonight
camerooch Member 129 Member For: 23y 4m 9d Location: Melbourne Posted 24/09/03 04:06 AM Posted 24/09/03 04:06 AM Whatcha driving & more importantly,....... What were you towing ??
ASNU Member 261 Member For: 23y 8m 5d Location: Brooklyn Posted 24/09/03 04:52 AM Author Posted 24/09/03 04:52 AM Whatcha driving & more importantly,....... What were you towing ?? A duel axil trailer with brakes mate with about 500kg in it plus loaded in the back.I tow these loads in my ute all the time and does it quite easily,The diff houseing is supported either side with rubber bushes for sound dendening and smoothness of ride I assume but it really does not need much to move the diff and chop out the bushes if any load is put onto it.My old AU2 XR8 never had the problem and I would think maybe the old car had larger centreing bolts maybe.I can just see everybodys ute having the same problem as the bushes play a important part in centreing the diff.Running this much power threw to a 8 mm bolt is only going to cause distress.
Turbo6man Legacy Donating Member 4,084 Member For: 23y 11m 21d Gender: Male Location: South Coast NSW Posted 24/09/03 08:24 AM Posted 24/09/03 08:24 AM ASNU> I think you're being a bit hard on the bolt - it is not meant to do anything more than hold the spring pack compressed together for assembly and to locate the lower (U-Bolt) clamping bracket - the U-Bolts take the load of holding the axle under lateral and longitudinal forces not the centre bolt. I would suggest your U-Bolts were not torqued to the correct tension and this allowed the beam axle to move and sheer the centre bolt.
ASNU Member 261 Member For: 23y 8m 5d Location: Brooklyn Posted 24/09/03 08:56 AM Author Posted 24/09/03 08:56 AM I think you're being a bit hard on the bolt - Turbo6man.When you have time if possible,Jump underneath your silver monarch and enlighten me what holds the leaf springs together under the 9 inch mate.The 8mm bolt is a combination of the failure which occured while under load when the bushes started to wear..Of course the bolt is not the pivot of all load as as you suggested and the U bolts were probley not tensioned properly or was it for say an example the bushes failing then leaving to much room for forward and backward movement.Regardless I am going to modify the rear bolts with larger items and would like to persue the idea of a panhard rod fitted to the chassis somehow to stop flex.Maybe I should buy a rear half cut of a 351 XA-XB with a trusty old 9 inch with bar fitted already,Probley cheaper.
Turbo6man Legacy Donating Member 4,084 Member For: 23y 11m 21d Gender: Male Location: South Coast NSW Posted 24/09/03 09:19 AM Posted 24/09/03 09:19 AM ASNU> The leaf spring centre bolt under the LTD is about 3/8" dia from memory.
ASNU Member 261 Member For: 23y 8m 5d Location: Brooklyn Posted 24/09/03 10:36 PM Author Posted 24/09/03 10:36 PM The leaf spring centre bolt under the LTD is about 3/8" dia Built properly from the start.The designs of the older cars with big heavy dutie diffs and suspension was so good,Inderstructable.I was wondering last night if when they introduced the on the market with the 351 and 9 inch if the rear leaf springs were the same as today as the ute rear end has not changed since the .This might be a consideration if the diff pops in later life.
Turbo6man Legacy Donating Member 4,084 Member For: 23y 11m 21d Gender: Male Location: South Coast NSW Posted 26/09/03 01:59 PM Posted 26/09/03 01:59 PM ASNU> Well actually NO they weren't really built any better from the start - the Silver Monarch is constantly "walking" it's back axle around. It has a 350 HP Cleveland and when I'm towing it can go all-up weight of close to 4 tons. The U-bolts just can't seem to clamp down enough on the rubber bushes and I had to replace them with urethane. Haven't broken any centre bolts though.
ASNU Member 261 Member For: 23y 8m 5d Location: Brooklyn Posted 28/09/03 10:13 PM Author Posted 28/09/03 10:13 PM - the Silver Monarch is constantly "walking" it's back axle around. It has a 350 HP Cleveland and when I'm towing it can go all-up weight of close to 4 tons. The U-bolts just can't seem to clamp down enough on the rubber bushes and I had to replace them with urethane. Haven't broken any centre bolts though. Where do you get the urethane bushes from mate?.I spose I could try Blueys ute world or something.Do they seem to do a better job?.
