  • Legacy Donating Member
  • Member For: 18y 9m 21d
Posted
Can this be done? My drivers seat is fairly flogged out being about 6 years old now, but passenger one is still firm as and in top nick. I understand I wouldnt have the up/down function on the seat, as this is drivers side only, but dont really care, just wanted to know if this could be done and done easily..
  • Are we there yet?
  • Member For: 23y 12d
Posted
There is a good chance that they are not interchangeable. They will probably face slightly differently on the rails so it will feel a little wrong when you sit in it.
The biggest issue would be all the electrics and adjustments are on the wrong sides.
If you were in Sydney, I could offer you a good deal on a set that are sitting in my garage... :roflmbo:
  • Member For: 22y 6m 8d
Posted
You will have fun trying to put your seat belt on when the buckle is on the same side as the belt ...
The cushions them selves could probably be removed and swapped over I suspect.
  • Member For: 18y 8m 11d
Posted
You can buy new seat base cushions from FORD with or without the trim seperately. As KAL_SPL said you can pull both seats out and remove the base assys,remove the trims and swap over the cushions. Alot easier to just get a new cushion if you have the coin.
