  • Member For: 18y 1m 11d
Posted
Hey guy's just wondering if anybody has had the same problem as me. I own a 03 BA XR6T I was driving down the M2 today and car sounded like it has a exaust leak (Aftermarket full system)
and then I realised when it come's on boost it's not responding but is still spooling up, the car is still to hot to check but could it be turbo gasket or exuast gasket or even worse f*cked turbo???
  • Forged Member
  • Legacy Donating Member
  • Member For: 19y 7m 25d
Posted
Could've lost a bolt out of the turbo too mate, check the ones that bolt into the rear housing - does it sound like a tractor or is it only a quiet leak?
Posted (edited)
Sounds a bit like a tractor
Edited by acid_rush
  • Banned
  • Member For: 17y 3m 21d
Posted
Your manifold bolts could be loose. When I pulled my turbo off they dont run a gasket fro the manifold to the turbo. Just pull off all your heatshields and take a look. You should be able to spot the leak then.
Posted
Thanks will have a look when I get home from work this afternoon cheers
  • 3 weeks later...
  • Member For: 17y 4m 11d
Posted
could be as the guys said a bolts come loose and leaking pressure
  • Member For: 18y 5m 19d
Posted
Happens all the time make sure you check all the bolts. I didn't check mine for a while and it ruined the gasket around the turbo to dump pipe :(
