  • Member For: 16y 5m 27d
Hi I own a BF MkII XR6T with 73000k's on the clock. I bought the car in feb this year with 65000k's on the clock and have noticed a 'rattling' noise from the front of the engine. It didn't make this noise when I first bought the car and now seems to happen more frequently.
The car is stock and has had all it's 'compulsory' services. Does anyone else have this problem? Is it just the timing chain?
Thanks for your help.
https://www.fordxr6turbo.com/forum/topic/60645-rattling-sound-from-engine/
  • My engine bay is Bionic
  • Member For: 19y 3m 18d
These cars rattle from every oriface. When they dont rattle we tend to worry. At a guess, engine mount on the drivers side that puts up with a lot of heat.
I.B.
  • loitering with intent
  • Member For: 21y 10m 18d
Sounds like a heat shield. Tighten it or piss it off. Noise will probably do the same
  • Member For: 20y
If its a tinny rattle it may be a heat sheild, but if more of a clacky rattle and towards the front, have your belt tensioner and idle pulley checked out.
  • Member For: 19y 3m 13d
so it didnt rattle before but after an oil change it rattles?
my car rattles in the front of the head with fresh oil in it, when it gets a bit brown the rattle goes away.
Yes exactly... it has fresh oil and I've been changing it every 5000k's. I'm using castrol edge sport 0w-40. Is this oil too thin? Should I use something else?
  • Member For: 17y 9m 26d
I noticed my engine rattled/noisier with castrol edge 0/40. I put Shell helix in there 10/50 and it's much quieter.
  • It's not a MKI!
  • Member For: 17y 18d
Yes it's too thin.
Try reading this for some enlightenment.
http://www.fordxr6turbo.com/forum/index.ph...st&p=917640
