  • Member For: 18y 3d
Posted
hey people im fitting new e-boost street boost controller I need rpm signal wire where can I find??
  • Member For: 19y 6m 15d
Posted
Lucky you. There is no rpm signal wire on an xr6t engine, you must buy a signal conversion box from www.shiftkits.com and wire it into the CAS wire, it will then convert the CAS signal to a regular rpm output signal which the eboost will read.
  • 1 year later...
  • Member For: 18y 2m 2d
Posted (edited)
I have never used an EBOOST,is the signal conditioning circuit able to be driven via an injector drive wire.
EG: use injector negative wire for cylinder 1 to give RPM reference to EBOOST.
I have used this method before for other vehicles and devices.
A reluctor interface is the correct name for this type of adaptor/convertor.
MSD also do a TACH ADAPTOR.
Edited by supercharged88
