  • Suspended
  • Member For: 18y 7m 25d
Posted
Hi just got the car retune at cv and got 316.5rw/kw mod walbro pump, kn filter, sieman injectors, 3" hi flow cat, and 2 half" exhaust.
  • Member For: 17y 9m 23d
Posted
How much boost and no cooler??
Nice result none the less
Did you get a torque reading?? must be very tough and strong
  • 777
  • Member For: 17y 8m 10d
Posted
Top result considering
  • Suspended
Posted
15 psi tough7500nm
  • Suspended
Posted
thanks I wont to run quater mile what times do you think I will do?
  • loitering with intent
  • Legacy Donating Member
  • Member For: 23y 1m 22d
Posted
just can't back it up. Heat soaked after a few runs.
Con will hve it running pretty rich I would imagine as a consequence
  • Suspended
Posted
I hope he has a cooler with that sort of power
why what will happen I got one but have not put it in yet soon
  • Suspended
Posted
I got told its around 11.8 12 afr is that to rich?
Posted
it's on the safe side as expected. Once you get a bigger cooler get Con to throw it up on the Dyno.
He can tweak your tune to suit. Won't need a lot of dyno time as he already has the base tune to work with
