May 14, 200917 yr #1 hi all just a quick one. has anyone put a free air 10" sub in the stock location using a spacer and has this worked ok?also does the sub unscrew fron underneath the parcel shelf or does the rear shelf need to be removed and the sub unscrewed from above?thanksscott
May 14, 200917 yr #2 I've wired up my 13.5 inch sub to the standard amp, got rid of the standard subwhole car shakes :stupid2:
May 14, 200917 yr #3 I just replaced the door and parcel shelf speakers in my BF tonight. It's got the Premium sound option but now sounds a lot better with some high quality speakers. Anyway, whilst replacing the rears, I got a good look at the factory sub. It is removed from the top.
May 14, 200917 yr #4 Top!But while its 'ok' to simply replace the speaker and/or sub without changing the amp, just be careful how you drive the new speakers... You may end up with some paper weights...
May 15, 200917 yr #5 Author I've wired up my 13.5 inch sub to the standard amp, got rid of the standard subwhole car shakes what type of sub you got dude?
May 15, 200917 yr #6 nothign sounds good up there , perform my icc rca mod chuck in an amp and sub in a box and ya boomin way better than any factory combo
