vetha Member 61 Member For: 18y 7m 13d Gender: Male Location: Melb, VIC Posted 14/05/09 10:57 AM Posted 14/05/09 10:57 AM I got myself some rims and when I got them I had 245 45 18's on them and hte front was clearly rubbing on some part of the suspension and I could hear it when I drove and also feel it in the steeringso I went and got myself 225 40 18's for the front and I looked at everyhting there cant possibly be any rubbing but still there is a noise and tight steering this has go me stumped to the maxwhat could it be????thanks samson
Locomick AK47's for everybody Legacy Donating Member 131 Member For: 20y 6m 10d Gender: Male Location: somewere Posted 14/05/09 12:22 PM Posted 14/05/09 12:22 PM did u get the rims with the right off set +36mick
keaton185 Member 301 Member For: 17y 7m 22d Gender: Male Location: Straya Posted 14/05/09 12:28 PM Posted 14/05/09 12:28 PM Only thing I can think of could be wheel bearing?
vetha Member 61 Member For: 18y 7m 13d Gender: Male Location: Melb, VIC Posted 14/05/09 01:28 PM Author Posted 14/05/09 01:28 PM heres something elsethe rubbing sound is there when the steering is straight and turning right but no sound whne turning leftalso just like out of no where my abs light turned on??I dunno if that narrows it downthanks samson
Erko Legacy Donating Member 1,079 Member For: 22y 11m 17d Gender: Male Location: Sydney Posted 14/05/09 11:14 PM Posted 14/05/09 11:14 PM get underneath and check for clearance on the inside to suspension arm......could be high offset ie. +45 or above wheels.
vetha Member 61 Member For: 18y 7m 13d Gender: Male Location: Melb, VIC Posted 15/05/09 06:31 AM Author Posted 15/05/09 06:31 AM can't see anything rubbing :(
turtl3tim Member 46 Member For: 17y 8m 4d Gender: Male Location: Perth, W.A Posted 15/05/09 11:02 AM Posted 15/05/09 11:02 AM (edited) put the old rims n tyres back on and see if the problems still there, the abs light coming on is very wierd. as mick said, check the offset, jack the front end up and see it the wheels are spinning freely and give them a shake to check the bearing, check power steering and brake fluid lol, look for signs of rubbing everywhere because when the cars jacked up the wheel moves outwards and may not rub anymore, check the inner wall of the tyre and the inside face of the rim incase its been rubbing on the caliper, apart from that its got me stumped to, unless the rubbing noise is cheap tyres and theres actually a problem with your steering rack/pump Edited 15/05/09 11:05 AM by turtl3tim
vetha Member 61 Member For: 18y 7m 13d Gender: Male Location: Melb, VIC Posted 17/05/09 10:40 AM Author Posted 17/05/09 10:40 AM could this be what brake shudder is? cause the steering wheel shudders too and when on freeway the abs light turns on?
jasol Member 571 Member For: 17y 7m 22d Location: adelaide Posted 17/05/09 11:19 AM Posted 17/05/09 11:19 AM have you tried your old rims yet like someone said erlyer? I recon it could be a wheel bearing/s
Tocchi Sandtrap Motorsport Legacy Donating Member 2,055 Member For: 17y 9m 25d Gender: Male Location: Perth Posted 17/05/09 12:59 PM Posted 17/05/09 12:59 PM you want 245/40 R18s,the 245/45 tyre are 1cm higher in diameter
