  • Member For: 18y 7m 28d
Posted
I already changed the tyres to 225 40 18s in the front
and I just tried the stockies and put them in the front still making a noise which means it cant be the rims
steering is tight when turning right no problems turning left and the vibrating/noise comes when going straight or turning right
what could it be?? wheel bearings?
at least I got the rims being the problem out of the equation
  • Member For: 17y 8m 5d
Posted
if its bearings you can usally jack the front end up so the front rims are off the ground and try and wiggle the rim if theres any movement there stuffed, that being said though if theres even just a bit of crap or some metal has grinded in the bearing it will be noisey, best bet take it to a mechanic you trust let him hear it, it wont cost you anything and ill know
Posted
yea that's the problem finding someone you can trust is not easy
im guessing now its either wheel bearings or steering rack
Posted
can I just ask... could it be the power steering pump? cause it does get louder as the car gets faster
(the noise kinda like a rattling, whining rubbing noise hard to describe)
cause I was thinkin if its the power steering pump struggling to work then that's y its getting louder the faster u go
I dont know does that sound right?
Posted
mate I think the kind people on here have given you about all the help they can without seeing it, it doesnt sound healthy so I would take it to a site sponsor or decent mechanic and have it looked at asap
Posted
alll doneeee fixed it was the wheel bearings
