Strange Brake Problem (unlike Anything I Have Seen On Forums)
  • Member For: 16y 11m 14d
Hey guys,
Basically I spent the last hour or so looking for this issue, to no avail it seems no one has posted about it. Anyway, here is the problem... When I am slowing down at low speed (25km>), the front brakes seem to kind of grab and then let go, this happen up to 3-5 per second, kind of sounds like morse code. It does no sound like scraping or anything like that, more of an electric sound, I guess you could compare it to the abs testing itself. Almost always happens when turning left at low speed, pulling into driveways and such. I guess I am just a little at my whits end with it, as I am having to pay $900 for a diff rebuild next week, plus service, plus another weird enpine/acceleration problem that I will not speak of here... Any insight would be greatly appreciated. Oh, and it's a BA XRT 2003 - Auto. Thanks again
Ps- Very rarely, if it has a serious fit, the abs and traction control light will come on and not turn off, I have to restart the car to fix it. (Perhaps a faulty abs fuse?)
  • BOOST
  • Moderating Team
  • Member For: 21y 7m 26d
If the light is coming on "sometimes" then id be thinking the Abs system is on the way out
  • Member For: 21y 2m 18d
The same sensors that dot he ABS also do the TC, so it does indicate a problem with the ABS wheel sensors.
I would take it to a brake place for a checkover, as it looks like the ABS thinks your wheels are locking.
  • Sucker
  • Moderating Team
  • Member For: 21y 7d
:bsflag:
...but get it looked at ASAP. Not something you want to stop working all of a sudden! :pinch:
  • Member For: 16y 6m
its most liekly just excessive build up of metal filings on the sensor, but it may well have a sensor that needs replacing.
You can clean the sensor off yourself if you're willing to get a bit dirty, or easily enough have it checked out by a brake specialist
  • Member For: 17y 3m 1d
Ford will tell you exactly which wheel speed sensor is faulty within 20mins. If it is a WSS fault and the light stays on like you say it would have logged a memory code for which sensor it is. As said,if you have had a disc machine or something recently the metal can cover the end of the sensor which will also log a code as a faulty sensor. Good luck mate.
  • Member For: 18y 2m 11d
I had the exact same problem mate.
When slowing down and coming to a stop the abs would come on.
Found out one of my abs sensors wasn't fitted correctly after having the diff bush done, it would be fine at speed but when coming to a stop the ecu would think a wheel is locked and apply abs.
I took all the sensors off, gave em a decent clean and re-installed them. it wasn't till I got to the last one that I found the bolt was loose and I could move it around - just my luck.
Now its good as new.
  • Enforcer
  • Member For: 16y 6m 22d
Hey guys,
Basically I spent the last hour or so looking for this issue, to no avail it seems no one has posted about it. Anyway, here is the problem... When I am slowing down at low speed (25km>), the front brakes seem to kind of grab and then let go, this happen up to 3-5 per second, kind of sounds like morse code. It does no sound like scraping or anything like that, more of an electric sound, I guess you could compare it to the abs testing itself. Almost always happens when turning left at low speed, pulling into driveways and such. I guess I am just a little at my whits end with it, as I am having to pay $900 for a diff rebuild next week, plus service, plus another weird enpine/acceleration problem that I will not speak of here... Any insight would be greatly appreciated. Oh, and it's a BA XRT 2003 - Auto. Thanks again =quote)
Mate, I know the exact noise that you are talking about.
It happens with my car every single morning as I am turning left out of my drive way and it has happened from new. Mine is 07 BF ZF.
I figured it was the abs coming on line? and doing self check or something, to me it sounds like a solenoid flicking rapidly on and off about 7-8 times in about 1.5 seconds; but it is sure coming from around the left/front wheel, maybe the ecu?
Edited by lowfutura
  • Member For: 16y 9m
Hey guys,
I have the exact same Problem on my BA xrt 03 as well. havent had the time to run it round to a mechanic. if you end up finding the problem post it up.... cheers
