  • Member For: 17y 9m 21d
Posted
Hello all,
I bought new globes and ive hit a road block... the battery.
Is it possible to change the bulb without removing the battery or have I just got large hands?
Secondly, this is the first time the bulbs have been changed since factory. should they be hard to remove ( as in connector stuck on globe?)
cheers
  • Legacy Donating Member
  • Member For: 22y 7m 18d
Posted
some skinny girly handed people have managed to change them without removing the battery/airbox, but I tried and lost a fair chunk of skin trying.
I now just rip both out in a few mins and easily get the globes out.
As for the plug, you need to squeeze it, as it is clipped onto the globe.
There is also a metal bar that is holding the globe into the headlight. Have a quick read of the manual if you need more details.
Posted
cheers... will try again in the morning when there is more light.
Ive changed them in a AU before and I didnt have as many problems.
I knew about the spring behind the rubber cap but not the connector.. the manual is very vague about that part.
  • Member For: 19y 10m 17d
Posted
Good luck mate I actually had to change mine AGAIN this morning on the battery side... truts me its just quicker to remove the battery so you can unplug remove etc the first time.. should only take you 5mins.
  • Member For: 19y 1m 9d
Posted
10mm socket.... loosen head light.... fast as a F1 pit stop
  • 3 weeks later...
  • Member For: 17y 11m 6d
Posted
remove the plastic shroud that is around your battery perminatley. its just for looks and is annoyin lol... as for the airbox side unclip it as if your changin the filter to get more access. bobs your uncle
  • 2 months later...
  • 2 months later...
  • Member For: 17y 14d
Posted
whatever you do becareful not to lose the metal clip, mine came off and fell into the headlight assy, there is a nicer gap just below for some reason and it fell it and I coudlnt get it back out, my mate who was a panel beater we ended up taking off the front bar and getting the headlight out so we can shake the damn thing out, I know get the local garage to change the bulbs so they can deal with the problem, seriously ford, sif you couldnt have come up with a better solution to holding the bulbs in
  • 2 weeks later...
Posted
its terrible.. like instead of it just costing $30 for a new set of bulbs, its now another $100 to get someone to install it.. I had a hard enough time jamming my hand intot the front bar to replace a blown fog light
Posted
I know mate, although the local garage are pretty good to me and only charged me 20 bux, then next time didnt charge me at all, I have actually bought a hid kit this morning so going to install that on the weekend then I shouldnt have to worry about it anymore :)
