  • Member For: 17y 1m 9d
All my rotors are pretty well stuffed so I'm looking at doing some sort of upgrade. Vehicle is a 03
BA xr6T auto its got the PBR upgrade I believe.
Options I have been wondering about is,
Getting some standard rotors and getting them slotted? put some good pads on blah blah..
Also have wondered about putting BF rotors and calipers on, Is this very hard to do and will it make a huge difference?
Any other options will be considered but I don't particularly want to spent thousands.
Thanks Ben
https://www.fordxr6turbo.com/forum/topic/54551-options-for-brake-upgrades/
  • Forged Member
  • Member For: 18y 3m 15d
If most of your driving is done on the street, I would get some Good Slotted rotors (DBA4000) and some decent pads (PBR or Ferodo) - that should do you well enough
  • Forged Member
You can mix and match if you like, however an even upgrade in brakes is always a good idea for the best results.
  • My engine bay is Bionic
  • Member For: 19y 2m 3d
If one changes the rotors (DBA4000) + pads at the front, do you have to change the rears as well? Can the rears stay stock???
Not really. I did the fronts first and the backs some months later. If the fronts are done with a better braking setup then you will feel it in the rear but only under spirited driving, the everyday stuff wont make a difference.
I.B.
  • 1 month later...
  • Member For: 19y 10m 15d
The change over is very straight forward, as the mounting points are exactly the same.
  • Member For: 16y 3m 17d
I would recommend the 4 pot Brembo upgrade.
I picked one up off ebay for $1,800 which was for a brand new front kit including calipers, drilled and slotted rotors, lines and all mounting requirements to fit to a ba falcon.
Fitment is super easy.
Definitely worth considering in my opinion
Lorenz
cept I don't realy have 1800$ just sitting around lol. am seriously concidering the bf calipers with some dba slotted rotars... how much better will this be and will I have any problem with abs or anything?
