Interior Lights Wont Work And Door Ajar Light Stays On
Featured Replies
#1
Hi Everyone,
I have a BA. Only the last couple of days when your driving along the door ajar light will come on when all the doors are properly closed. to top it off the key hole light on the steering column stays on yet no interior lights will work. Anyone have any ideas.....cheers
#2
Mate - your car knows its the weekend and therefore is putting a club's light show on for you!
Turn you radio up and put on some doof doof and it might fix it all up!
:stupid:
On a serious note, check the glob in the roof light, as well as the swtich is in the auto position.
Check all the trigger points on each of the doors, as well as in the boot!
See if this helps at all!
#3
I know it sounds too simple...but this did happen to me when I got the car back from the panel beater and I thought they had buggered something up. No courtesy lights and the door ajar light always on.
My simple solution was to replace the blown blue 15amp fuse under the dash....then lights came back and door ajar light went out.
Sounds simple....worth a try?
#4
I agree with Sark021 had the same problem and all I needed to do was change a fuse
Recently Browsing 0
