MaTTe Member 143 Member For: 17y 11m 11d Location: Perth Posted 19/12/08 02:19 PM Posted 19/12/08 02:19 PM if you have a spare that matches the set, then swap it onto the car, and keep this one as a spare.If you don't have a spare that matches the set, it's time to buy a new tyre as you alread have yourself a spare..Tempting fate is not worth the consequences. The tyre is still useable for a standard drive if/when you have troubles with another of your tyres.
ms700 Moderating Team 10,170 Member For: 23y 8m 11d Gender: Male Location: Sydney Posted 19/12/08 10:06 PM Posted 19/12/08 10:06 PM Pump it up, put it on the back and burn it, at least you'll get some fun outta it!
alpha Member 266 Member For: 19y 7m 8d Gender: Male Location: Perth Posted 19/12/08 11:19 PM Author Posted 19/12/08 11:19 PM Yeah the guys originally plugged it but was leaking from the plug then they patched a large area from inside. .. still leak. I think I going to take the majority advice and order a new tyre... damn those 19" tyres are expensive!!!!
wiresquire Member 266 Member For: 21y 10m 16d Posted 27/12/08 12:44 PM Posted 27/12/08 12:44 PM Sorry for bumping the thread, but thought it was better than starting a new one. I've had a tyre punctured and repaired recently. I've got a shiny new spare in the boot which probably has 0k on it. The others are ~15K of easy (relative to most other forum members) driving and look to be in good nick and have plenty of tread left.My poor brain seems to think I should fit it to the rear, cause you wouldn't want the front wriggling. But then maybe more grip should always go on the front. Buggered if I know if ABS is per wheel or not...So, the question is if I change the spare to replace the plugged one, should I fit it to the rear or the front?Cheersws
Iconic Bionic My engine bay is Bionic Legacy Donating Member 3,726 Member For: 20y 6m 23d Gender: Male Location: Freeways Posted 27/12/08 11:19 PM Posted 27/12/08 11:19 PM Dont get the ABS issues, but it does not matter where you put the tyre, if the others are reasonably good. Generally your better rubber should go on the front.I.B.
RHR BOOST Moderating Team 5,698 Member For: 23y 1m 7d Gender: Male Location: Southern Highlands NSW Posted 27/12/08 11:23 PM Posted 27/12/08 11:23 PM If you think it will affect your ABS you can now breath easy as it wont.
