bjc Legacy Donating Member 2,823 Member For: 23y 15d Gender: Male Location: Townsville Posted 07/12/08 09:29 AM Posted 07/12/08 09:29 AM If tyre wear is even then you certainly dont need a camber kit, just a wheel alignment because it is pulling one way
Iconic Bionic My engine bay is Bionic Legacy Donating Member 3,726 Member For: 20y 5m 30d Gender: Male Location: Freeways Posted 07/12/08 10:07 AM Author Posted 07/12/08 10:07 AM Well I got off me ass and had a proper look and the left front is slightly wearing on the inside more then the other side. Its now worn beyong the TWI where as the other side is just above the TWI.Still think just wheel alignment?? I know ordinarily our roads camber to the left.I.B.
bjc Legacy Donating Member 2,823 Member For: 23y 15d Gender: Male Location: Townsville Posted 07/12/08 10:37 AM Posted 07/12/08 10:37 AM Stick with just a wheel aligment for now but they will be able to give you numbers of what each side was at camber and toe wise.If the tyres have been rotated also this can be the reason for uneveness due to one wheel spinning out of a corner for instance, they rotate that tyre to the front and its already worn more than the others!Get the wheel alignment done as they are reasonably cheap, get the figures from the tyre bloke and go from there.
