Jman The Cleaning Dudes Ute Silver Donating Members 1,308 Member For: 19y 3m 6d Gender: Male Location: Bentleigh, Vic, Australia Posted 11/11/08 04:49 PM Share Posted 11/11/08 04:49 PM (edited) Hi guys.I'm getting my first lot of mods done in the next month or so. I'm planning on doing the front half of the exhaust dump/cat (using the stock exhaust minus middle muffler)... then doing a catback custom job on the 2nd round of mods.For the first round I'm trying to push over 330rwkw's.I've been looking around specifically for a 4inch dump pipe. Most of the brands that I've seen the 4" dump pipe starts as a 4inch pipe then tapers down to a 3.5 exit for the cat. Is this the case with all 4" dumps?Then with the 3.5's that I've seen... they taper down to a 3inch.I'm trying to find a 4" dump pipe which stays that thickness right through.Any advice please... I'm all ears.Cheers,Jarrod Edited 11/11/08 04:51 PM by Jman Link to comment https://www.fordxr6turbo.com/forum/topic/51576-dump-pipe-question/ Share on other sites More sharing options...
typhoon_freak Cryptic Clothing Company Donating Members 4,556 Member For: 17y 8d Gender: Male Location: Brisvages, Capalaba Posted 11/11/08 07:55 PM Share Posted 11/11/08 07:55 PM yeh, the most iv seen start as a 4in and taper to 3.5.. I think this is cause u have the air comming from the turbo as well to be joined into the exhuast? depends if u want a joined dump and split dump.. I got a split dump with 4inch that runs thru a twin 2.5in.. I dont think having a 4in all the way thru would matter, as the dumps can support a far amount of airflow as it is. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/51576-dump-pipe-question/#findComment-766504 Share on other sites More sharing options...
Guest Guests Posted 12/11/08 12:34 AM Share Posted 12/11/08 12:34 AM SMB are 4' all the way through Link to comment https://www.fordxr6turbo.com/forum/topic/51576-dump-pipe-question/#findComment-766620 Share on other sites More sharing options...
Jman The Cleaning Dudes Ute Silver Donating Members 1,308 Member For: 19y 3m 6d Gender: Male Location: Bentleigh, Vic, Australia Posted 12/11/08 12:43 AM Author Share Posted 12/11/08 12:43 AM What are the advantages of having a single vs split system? Link to comment https://www.fordxr6turbo.com/forum/topic/51576-dump-pipe-question/#findComment-766628 Share on other sites More sharing options...
Guest Guests Posted 12/11/08 12:48 AM Share Posted 12/11/08 12:48 AM The smaller the dump, the quicker the car spools up. The larger it is the more power it can make.In a nutshell, I don't see a difference in having a split 3"/1" dump compared to a straight 4". there's still 4" of space to fill Could be completely wrong though? Link to comment https://www.fordxr6turbo.com/forum/topic/51576-dump-pipe-question/#findComment-766634 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 5m 11d Gender: Male Location: SW Sydney Posted 12/11/08 12:51 AM Share Posted 12/11/08 12:51 AM The main arguement for the split pipe is that it keeps the flow from the wastegate separate from the main exhaust flow. This is supposed to reduce back pressure and increase response. Link to comment https://www.fordxr6turbo.com/forum/topic/51576-dump-pipe-question/#findComment-766640 Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 11m Gender: Male Location: Broady, Melbourne Posted 12/11/08 02:22 AM Share Posted 12/11/08 02:22 AM Turbulence.I've spoken to a tuner or two who likes the split dumps for the sub 400 region. I spoke to a bloke from QLD who said he went from a 4inch to split and ended up making more power. My friend at pro flow also prefers split dump pipes. Everyone has an opinion...*actual results may vary Link to comment https://www.fordxr6turbo.com/forum/topic/51576-dump-pipe-question/#findComment-766711 Share on other sites More sharing options...
bigmat Donating Members 87 Member For: 18y 1m 14d Gender: Male Location: Gisborne NZ Posted 15/11/08 10:39 AM Share Posted 15/11/08 10:39 AM The smaller the dump, the quicker the car spools up. The larger it is the more power it can make.In a nutshell, I don't see a difference in having a split 3"/1" dump compared to a straight 4". there's still 4" of space to fill Could be completely wrong though?Hmmm lets see I don't think it is quite that straight forward....Area of a circle = pi * radius2 (dump pipe) in this case3" and a 1' equal (in metric to stop confusion about multiplying halves etc ) 38mm = 1.5' = radius of main pipe and 12.5 = 0.5 radius of wastegate pipe.so 3.1428 x 38 x38 = 4536 cm squared+3.1428 x 12.5 x 12.5 = 491 cm squaredTotals = 5027 cm squared BUT 1 x 4" pipe = 3.1428 x 50.8 x 50.8 = 8106 cm squared so by rights the 4" should flow about 60% better....Then I could be wrong too.....apart from a bit of rounding, I think I was once or twice in the past. Link to comment https://www.fordxr6turbo.com/forum/topic/51576-dump-pipe-question/#findComment-768943 Share on other sites More sharing options...
XRSCAR Member 414 Member For: 17y 5m 9d Gender: Male Location: FTG, Victoria Posted 15/11/08 11:47 AM Share Posted 15/11/08 11:47 AM To much maths for a Saturday night bigmat! hahahahah Link to comment https://www.fordxr6turbo.com/forum/topic/51576-dump-pipe-question/#findComment-768961 Share on other sites More sharing options...
bigmat Donating Members 87 Member For: 18y 1m 14d Gender: Male Location: Gisborne NZ Posted 15/11/08 11:25 PM Share Posted 15/11/08 11:25 PM To much maths for a Saturday night bigmat! hahahahahyeah possibly it was just about sunday morning here too....but I think one 4 inch pipe would flow better than a 3 and a 1 but then you take into account scavenging effect and back pressure, separation and all those other things like thermal dynamics bla bla (I almost sound like I know what I,m talking about... wrong....) and the 3 and 1 may work better then the 4.... in all but the biggest horsepower applications... Link to comment https://www.fordxr6turbo.com/forum/topic/51576-dump-pipe-question/#findComment-769030 Share on other sites More sharing options...
