Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 24d Gender: Male Location: Perth Posted 11/11/08 07:28 AM Share Posted 11/11/08 07:28 AM Could be yout tub liner striking the support braces or some thing between the braces and liners (ie a rock or pebble). My fuel flap door used to rattle in the clip the holds it shut until i tweaked it so it gripped the door tighter. Link to comment Share on other sites More sharing options...
tig Donating Members 735 Member For: 16y 9m 13d Gender: Male Location: kenthurst, Sydney Posted 11/11/08 08:37 AM Share Posted 11/11/08 08:37 AM Adrain,Check the U bolts that secure the diff to the springs and the spring mounting bolts from and rear on each spring. They loosen up as the rubbers wear, this allows the diff to walk around on the springs and knock. The loose spring mounts/hangers allow the springs to slide sideways and knock on the hangers and mountsMy FG ute had U Bolts loose when I took it back to ford for diff clunk. They assumed it was the loose u bolts causing the clunk, unfortunately it wasn't that simple and it was the diff which I am waiting for replacement to come in. But yeah loose u bolts have been loose on a few FGs according to service guy so as a matter of course they should be checked. Link to comment Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 19y 5m 14d Gender: Male Location: SoR, WA Posted 11/11/08 10:15 AM Author Share Posted 11/11/08 10:15 AM Well I got under there after work (I have a pit in the shed which makes it so much easier) and went to torque the U Bolts but unfortunately I did not have a deep 21mm socket. So I snooped around and found this loose first.Yep, spare tyre was wobbling around.Then I had a look at the suspension and noticed the rubbers looked like they were on there for 4 years.Also that the rear brake lines are rubber. Aren't they supposed to be braided.I then looked over my shoulder and noticed a bit of oil on the diff.Fun times ahead. Link to comment Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 19y 5m 14d Gender: Male Location: SoR, WA Posted 11/11/08 12:06 PM Author Share Posted 11/11/08 12:06 PM I change the diff oil in mine after about 8000k's shut it up for a while.Shut it up for a while? Which oil did you use? Link to comment Share on other sites More sharing options...
Guest Guests Posted 11/11/08 12:22 PM Share Posted 11/11/08 12:22 PM castrol SAE something something with friction adative already mixed in, as opposed to the one where you buy it and add it seperatlytheres a thread on here somewhere about which oil to use Link to comment Share on other sites More sharing options...
Guest Guests Posted 11/11/08 12:26 PM Share Posted 11/11/08 12:26 PM Go Royal Purple oil Adrian. There's a supplier off Dixon Rd called 'Auto Haus', just ask for Neil & tell him Dean with the XR6T sent you. I'll be switching when I service the diff soon Link to comment Share on other sites More sharing options...
Guest SHADEY Guests Posted 12/11/08 07:48 AM Share Posted 12/11/08 07:48 AM check hand brake adjustment ? if the rear hand brake shoes have been over adjusted it can cause them to grab & make clunking noise as they let go??? Link to comment Share on other sites More sharing options...
cjsxrt Donating Members 145 Member For: 15y 5m 4d Posted 13/12/08 08:57 PM Share Posted 13/12/08 08:57 PM hey champ when I got my ute home dad and I heard a knock in the rear end we found out it was the rear axle bolts loose lucky dad is a mechanic so it cost me any thing to fix it Link to comment Share on other sites More sharing options...
majin Member 40 Member For: 16y 9m 6d Gender: Male Location: BrisVegas Posted 30/03/09 11:58 AM Share Posted 30/03/09 11:58 AM mine does sorta the same thing, slight knocking noise when you put your foot on the accelerator. ford said it was diff backlash, they replaced my lsd diff, and now it still does it......dunno anymore Link to comment Share on other sites More sharing options...
Brandonn Donating Members 2,304 Member For: 15y 8m 2d Gender: Male Location: port hedland Posted 30/03/09 12:14 PM Share Posted 30/03/09 12:14 PM ask mitch in sunny coast quen thread * queensland he had this problem recently had heaps of dodgy answer from ford n every took ages to get fixed but was simple in he end cant remember exactly but pm him or something u can find him where I said ^^^ Link to comment Share on other sites More sharing options...
