  • Member For: 18y 1m 8d
Posted
Hey All,
my XR6T headlights never turn off....not too sure if it s a feature from ford but how do I set it back to only turning on when I turn the light knob...because right now, as soon as I turn on the car, the headlights come on...
  • Sucker
  • Moderating Team
  • Member For: 22y 4m 27d
Posted
What model are we talking and did you order it with the "lights on" feature?
Posted
I've got an 03 BA XR6t and no I bought the car second hand so I dont know....
I thought it was just a feature which can be turned on and off in the car!!!
  • Sucker
  • Moderating Team
Posted
It is a separate loom that should be strapped behind your fuse block or under the dash, to disable it you need to remove that. No actual switch for it unfortunately.
  • Member For: 21y 9m 11d
Posted (edited)
Here's some pics from when I disabled the ignition-on feature on my FG. Was the same setup as my previous BAII's. Just remove the blade fuse and its all good. I ran my cars like this for near 2yrs without issue.
With the fuse removed, you can use the auto feature on the headlight stalk so they only come on when the sensor thinks they should be on.
http://www.fordxr6turbo.com/forum/index.ph...mp;#entry727439
Edited by dave-
