  • Member For: 18y 1m 12d
Posted
Im trying to get live link to work with the xcal 2 (flash 2) box but keeps tellng me Device intialization failed when I load up livelink. Installed drivers and checked them they are fine. Im using windows vista. Anyone know how to get this thing to work? Im sitting in the car atm and have run out of ideas, any help appreaited.
  • Member For: 23y 8m 22d
Posted
im having the same problem using windows XP. emailed SCT a month ago and still no reply.
  • iTs alL DaRDy........
  • Legacy Donating Member
  • Member For: 19y 19d
Posted
I had the same problem.
I recon I googled it and came up with an awnswer.
sorry cant rememebr what I did
  • Member For: 20y 6m
Posted
I had the same problem, it was the settings in livelink.
you need to select xcal2 in the settings and put in the code from your car. not too sure on what it was called posibly haap code or similar
Posted
I set it to Xcal2 and entered code HACCE, though it does say you dont need code if it is connect to car.
I changed the program run in Compatable XP mode, and turned user auth accounts off.
Once I did this the Flash box now beeps when I push Start data logging and says ACTIVE, then drops out and the laptop says DEVICE LINK FAILED or something! ! !!
BFHOON - Did you use windows Vista?
  • New Member
  • Member For: 18y 3m 19d
Posted
to get it working in vista go to the live link icon click on properties set it to run in xp sp2 untick visual themes and tick run as administrator and hopefully it works that's what I did
Posted
Thanks tried all that the box makes its noise but then drops out and says device failed to connect. Anyone got any ideas?
  • Dr. Speed
  • Member For: 19y 1m 24d
  • Location: The land of Politicians, Public Servants, Porno & Pyrotechnics
Posted
I had the exact same problem. I followed all instructions to the letter and it still wouldn't work. I spoke to my tuner and he reckoned he might have to unlock something in the box itself.... I never bothered getting him to do it....
Let us know if you get a definite answer.
  • 2 weeks later...
Posted
Got the thing working tonight, didnt do anything different? Just ran in XP compatabile mode, User accounts ON ( was off - but should be off SCT site says) and Run AS admin.
How do you work out Air fuel ratio? I also tried desired boost and says im boosting to 22lbs - think I have a leak somewhere. My BOV has been very loud the last week too.
  • Cryptic Clothing Company
  • Member For: 18y 2m 14d
Posted
well I downloaded the livelink v4 which seems to b the only one working proberly for me on the comp.. ran the program in xp mode.. still comes up with device failed to connect. I just want it to work!
