  • It's All In Your Mind
  • Legacy Donating Member
  • Member For: 22y 11m 11d
Posted (edited)
Had a good dose of rain in WA WA land lately and opened the boot to find the plastic bootliner about 3 inches deep in water. We had a Company BF 11 do the same thing. I am in Brissie at the moment and have left it with Titans to get fixed. They didn't seem to think it was common, anyone else had this happen and where was it getting in. The only place I could see where it might is around the strut mount points? :buttonit:
Also check your R Spec wheels if you have one as my front drivers side wheel has begun to oxidise under the clear around the centre cap, too costly to leave and miss warranty. :ph34r:
Edited by hypnodoc
  • Mmmmm......BOOST
  • Member For: 19y 5m 13d
Posted
were you parked facing down hill ,I have seen it happen when cars are parked nose down ,the wells near the boot struts fill up and it runs over the rubbers
Posted
Hey our06t. Cheers, that's the weird thing it is parked on the flat. I'm thinking it seeps in around the strut mount bolts or through the lower rear screen. Ford are going to lock some guy in the boot with a torch and turn the hose on it so I will post up the diagnosis
  • Mmmmm......BOOST
Posted
sounds like an interesting way to diagnose the problem ,Should work though
  • Member For: 21y 3m 18d
Posted
lucky its not me deciding when a ford service tech gets to come out!!
  • Member For: 19y 1m 22d
Posted
"While your there, does my subby play well at 150db"? Now that's what I'd be wondering...
Posted
'perhaps while your in there you can do some light reading.... OF THE FORD SERVICE MANUAL!!'
Posted
Was a faulty boot sealing rubber. They put on a new one and it sat in the rain all last night with no water in the boot this morning. The oxidising rim is now on ford back order so it should get here sometime before 2010. They must have had a faulty batch if it has to be factroy back ordered
  • 3 weeks later...
  • Member For: 22y 8m 20d
Posted
Also mate water can leak in through the licence plate screw holes as well. I put some adhesive rubber over the screw holes and then screwed the licence plate on. Fixes it well.
  • Member For: 18y 2m 13d
Posted
lol!
Yeah seen this on a few! The clear coat eventually starts to lift and looks like ass! Backordered parts is a pain in the ass! Can be annoying with the delay on getting the bits
Cause as it may be known not all aprts are made in a ford plant! Some stuff has to be sourced from outsdie manufacter's so a delay is in place!
And considering it been aproblem I say a manufdactor has had its ass kicked and told to fix the problem with rest of stock or a new manufactor has been sourced!
As for the water leak in the book there no better way of finding it. Might as well simulate the situation so a resolution can be made!
