Fg Flash Tuner
Featured Replies
#1
Hey guys,
Ive read the new FG 6T runs about 10psi now is that true? Also what will happen with the Capa generic flash tuners seeing they give you a 10psi map. Will they increase the psi a little more to compensate for the increased boost pressue on the new FG or something else?
Cheers :spoton:
#2
Standard xr6T runs 10 psi too its in the press release on fords website..
Something about changes to the turbo too. they say the brand and I think model but I am not familiar with bf to know if its a different turbo or just increase in boost from bf 6psi
either way I am waiting to test one again when its dry
cheers utemad
#3
Correct me if im wrong but I think the FG uses the same(ish) Turbo with a smaller compressor wheel running 10psi, gives better throttle response and boosts quicker, but I think the new Garret turbo is specific to the FG Ford, where as the BA and BF it was a out of the box bolt on.
Edited by Dagabond
#4
xr6 2001 your spot on. I know they are using the same turbo as BA/BF and yes they are just running a smaller compressor wheel to reduce lag I imagine. I am not sure wether they turbo/compressor set up is just for ford or is a blot on.
#5
The increase in compression ratio assists with the reduced lag also..
#6
I thought the engines now have a lower compression ratio - 8.47:1
#7
Only on the F6. The XR6 Turbo went from 8.7 to 8.8 comp.
#8
  • Author
does anyone know what will be happening with the flash tuners in regards to the increased boost in the FG...?? will they bring out a 14psi or something generic tune etc?
Recently Browsing 0
