Gloo Member 403 Member For: 17y 14d Gender: Male Location: Northern South Australia Posted 04/06/08 09:40 AM Share Posted 04/06/08 09:40 AM Ok had a topic before about my newly orded exhaust, ment to be going on thuesday. Ok, so I got a call today while I was working away doing my thing and the bloke says... "Hey bud, none of my suppliers have 3.5" dumps with seperate wast gate pipes"So I have till friday to decide what to do with my zorst. Once exhaust is on im gettting injectors, fuel pump, valve springs and a custom tune done with stock cooler but with CAI. Not sure what kw's to expect but I want a dump pipe that will cope with the tune ok. As far as I know im going to experiance turbulance with a 3.5" with no waist gate pipe. What to do?Want some adive. Should I got for a 3" with seperate waste gate pipe, single 3.5", should I mod the 3.5" is a 4" to big for small power. Link to comment https://www.fordxr6turbo.com/forum/topic/46299-3-35-4-troubles-with-zorst-shop/ Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 10m 13d Gender: Male Location: The 8th Dimension Posted 04/06/08 09:46 AM Share Posted 04/06/08 09:46 AM X-Force do a 3.5" split dump Link to comment https://www.fordxr6turbo.com/forum/topic/46299-3-35-4-troubles-with-zorst-shop/#findComment-687846 Share on other sites More sharing options...
MiKa Donating Members 4,243 Member For: 18y 8m 29d Gender: Male Location: Melbourne, VIC Posted 04/06/08 09:54 AM Share Posted 04/06/08 09:54 AM The stock dump is good for 300+rwkw's.. You really only need to change the cat.. Your stock cooler will limit you power before your dump..I'd leave the stock dump, get a bigger cat and maybe a cat back system... Link to comment https://www.fordxr6turbo.com/forum/topic/46299-3-35-4-troubles-with-zorst-shop/#findComment-687849 Share on other sites More sharing options...
Gloo Member 403 Member For: 17y 14d Gender: Male Location: Northern South Australia Posted 04/06/08 09:58 AM Author Share Posted 04/06/08 09:58 AM I guess my guy does not use them then as a supplier. Do you have there details?I have noticed that alot of guys on here are using them, didnt pay enough attention t see that they had 3.5" spit dumps, but that would make it safe to say that they arent to bad then? Being so popular? Link to comment https://www.fordxr6turbo.com/forum/topic/46299-3-35-4-troubles-with-zorst-shop/#findComment-687854 Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 17y 10d Gender: Male Location: Loitering in SEQ Posted 04/06/08 10:03 AM Share Posted 04/06/08 10:03 AM call best mufflers in sydney there on the net & there agent for x force. in in tully & I had my exhaust 3 day later after I ordered it & im about 3000klm away. Link to comment https://www.fordxr6turbo.com/forum/topic/46299-3-35-4-troubles-with-zorst-shop/#findComment-687856 Share on other sites More sharing options...
Gloo Member 403 Member For: 17y 14d Gender: Male Location: Northern South Australia Posted 04/06/08 10:21 AM Author Share Posted 04/06/08 10:21 AM Im from adelaide, ill talk to my guy. I would prefer to have him do all the organising, I bring the money he does everything else. Ill mention to him about X-Force, hopefully something works out.While im here though, do you know if X-Force have a muffler that has 2 tips and fits on both sides of the xr6. My guy had one there but it was slighty to wide and would not be about to mount straight. So I have settled with resi's. Link to comment https://www.fordxr6turbo.com/forum/topic/46299-3-35-4-troubles-with-zorst-shop/#findComment-687871 Share on other sites More sharing options...
TornadoJudd Donating Members 818 Member For: 19y 3m 5d Posted 04/06/08 12:37 PM Share Posted 04/06/08 12:37 PM upgrade to a better cooler and just worry about replacing your standard cat with a high flow aftermarket one. Link to comment https://www.fordxr6turbo.com/forum/topic/46299-3-35-4-troubles-with-zorst-shop/#findComment-688043 Share on other sites More sharing options...
blueboost Member 1,204 Member For: 20y 11m 24d Gender: Male Location: Mackay NorthQueensland Posted 05/06/08 09:37 PM Share Posted 05/06/08 09:37 PM upgrade to a better cooler and just worry about replacing your standard cat with a high flow aftermarket one.very good advise. David Link to comment https://www.fordxr6turbo.com/forum/topic/46299-3-35-4-troubles-with-zorst-shop/#findComment-688853 Share on other sites More sharing options...
Gloo Member 403 Member For: 17y 14d Gender: Male Location: Northern South Australia Posted 06/06/08 09:42 AM Author Share Posted 06/06/08 09:42 AM :( I guess high flow cat only then. It has a cat back system already, 2x 2.5" from the center muffler which is hi flow. No rear muffler. Way to loud for me, rekon she might be defectable.Any way, not getting exhaust done with me guy, didnt want to help, said he only fit 3" split dump or 3.5" single dump. Gave up. Spend me hard earned money on some engine goodies and go the full zorst when needed.Thank you every one for your help, great advice.Aaron Link to comment https://www.fordxr6turbo.com/forum/topic/46299-3-35-4-troubles-with-zorst-shop/#findComment-689153 Share on other sites More sharing options...
