  • Well-Hard Bangin' Member
  • Member For: 19y 1m 22d
Posted
Sup y'all, have to take a break from my comic genius duties as I have a weird little problem!
easy cruisy driving as per most of my driving is, steadily through 1st, second and then into third. coming up from 40-50kms until 60kms is normal, and then 60kms comes and the car feels like it changes up a gear into fourth. the revs drop, I can feel the car loosen up as if it'd gone up a gear, and then I change into fourth.
:blink:
any thoughts ladies and jellybeans???
all comments questions and queries welcome, helpful or hilarious!!
Cheers
Dan
  • Sucker
  • Moderating Team
  • Member For: 22y 5m 16d
Posted
Torque convertor :blink:
...or has it just started doing this?
  • Member For: 20y 2m 5d
Posted
Torque converter locking up.. nothing to worry about and perfectly normal.
Posted
only noticed it over the last month or so...!?
and what erzactly do you mean by it 'locking up'?? as in it's not engaging until it's needed/required?
also wouldn't it only be doing that under a bit more load? not the other way around? ie: it doesnt do it under a bootful
Cheers
Dan
  • Legacy Donating Member
  • Member For: 20y 6m 21d
Posted (edited)
Your lock out is engaged, on the Ford it does this in 3rd and 4th gear. Think of it as an overdrive which is engaged at light throttle applications to drop engine RPM and save you fuel. 3rd gear lock out is not needed and a pain in the arse if you ask me. Only time I ever notice it is when the car is in manual or performance mode as any other time the car will sit in 4th gear cruising at any speed. Like you care about fuel economy if the car is in manual or performance mode. :Welcome2FordXR6t:
Edited by Fatsex
Posted (edited)
well thanks for the very informative response Fats, greatly appreciated!
seems as though everything is as normal, as I have only just started usuing manual mode all the time in the last month or so.
all good then,
Cheers all, and especially the Fat one!!
Dan
Edited by Superdan
  • Dropping a turd
  • Member For: 18y 11m 14d
Posted
Cheers
Dan
Just realized you had an auto. I have seen this problem before, you will find it is the thing connected to the gear shifter on the drivers side.
  • Member For: 21y 3m 19d
Posted
hahahaha nice
