  • Suspended
  • Member For: 18y 7m 17d
Posted
hi I have ba xr6 n/a flashed and custom tune it got 2 half '' exhaust I had a noise some were in the heat shield so took them all out the cat one to wil it do affect the performance. one thing else should my cat be flanged on or welded thank.
  • Here since the start...
  • Legacy Donating Member
  • Member For: 23y 5m 7d
Posted
Threads merged and moved.
The N/A guys will get onto it quicker if it's in here. :roflmbo:
  • Suspended
Posted
hi I have xr6 n/a I took all the heat shields off the car fills a little lost in power sorry the car has been flashed and acustom tune from c&v please help
Posted
Threads merged...
Again... :blink:
You were a problem child weren't you? :blink:
Removing the heat shields will have no effect on performance whatsoever.
In an N/A I'd be amazed if you could feel a slight drop in power. If you are worried get CV to run it up on the dyno again. :hohum:
  • Suspended
Posted
I was not problem child it just the last post no replyed that Y THANKS
  • 1 month later...
  • Member For: 18y 5m 14d
Posted
Removing the heat sheild wont affect anything .. they do keep heat in the Extractors , and Hot air flows faster than Cooler air .. Keep that in mind .. Some of the Nascar Guys uses Manifold Blankets , to preheat there Exhaust Manifolds ...
  • 1 month later...
  • Member For: 21y 11m 24d
Posted
..bear in mind if it comes to an insurance claim, if the insurance company wants to be difficult they could claim it as a 'modification' - if your car caught on fire (crash etc as happened to me, caught on fire apparently from tranny stick popping out and oil dumping on extractors) they could use this to claim damage to the wreck from your actions and possibly ask you to pay the difference.
Unlikely as it is, I thought I should mention it. I had a family member's car in for repair (front-ended a towbar) and the assessor queried the repairer about why the air snorkel was missing - seriously!
Other than that there's litttle reason to remove the shield from a vehicle with factory headers.. if anything it will increase heat damage to components nearby under extreme conditions (my extractors used to glow red-pink frequently :P)
  • rob327
  • Member For: 18y 6m 20d
Posted
ive seen claims knocked back before because the car had different rims.... implying that the same sized, yet non-standard rims are what caused the accident...
insurers can basically make their own rules... used to work at a repairer..
