  • Member For: 17y 11m 15d
im pretty sure is doesnt say a minimum of 95
it says for increased performence use 95
to answer your question a stock car shouldnt ping on regular unleaded so there maybe a problem
but like others have said dont be a tight arse and put atleast 95 in
  • Silver Donating Members
  • Member For: 20y 20d
definatly should NOT ping on 91 octane petrol. when mine was on the dyno I used 95 ron petrol and the afr's dipped into the 10's at the top end.
what rpm is it pinging at? a grindy turbo wont sound all that different to ping.
  • Sucker
  • Moderating Team
  • Member For: 21y 2m 18d
Have had mine running on 91 when stuck in the middle of nowhere a few times. Theoretically the engine is supposed to "detune" itself but I wouldn't make a habit of it.
Certainly wasn't any audible pinging.
  • Member For: 17y 10m 3d
It even says in the owners manual that it must run on minimum of 95 RON. So would would assume that Ford designed it to run on a MINIMUM of 95 RON.....
mine says this also. Recommended - Premium unleaded
  • Member For: 18y 2m
Some more intelligent replies and some not so. When I open up my fuel flap it says 'Ethanol (E10) Fuel suitable' and the owners manual says something like 'premium fuel recommended for maximum performance'. It was a simple question , is it usual for an XR6T to ping using regular unleaded. I was also asking if the engine de-tunes itself to handle the lower octane. Its got nothing to do with being a tight ass!
  • BOOST
  • Moderating Team
  • Member For: 21y 10m 8d
Mate as I said ive been in a number of t's with the ZF 6 speed that ping on WOT and I reckon that due to your exhaust and cai this could all relate
  • Into the laaaake
  • Member For: 18y 29d
Yeah I was wrong, you were right.
  • cj_ak
  • Member For: 18y 12d
The 91 fuel that your using could be crap as well, try a different station.
I was a stuck a couple of time and reluctantly filled up with 91. It was smooth as butter. Felt like crap though.
I was in the same situation a month ago. This time I had a flash tune on the car and it was again driving perfect.
Seriously dude, its not supposed to ping. Get 95!!!!
  • Member For: 17y 5m 25d
Rev is right, your bigger cat back alters boost pressure (higher) and with low octane fuel its pre-igniting.With those mods you must use 98 oct.It will also be more efficient.
