XRDOSE BIGRED Donating Members 1,410 Member For: 18y 1m 25d Gender: Male Location: Sth East Melb Posted 25/12/07 12:06 AM Share Posted 25/12/07 12:06 AM hey guys just wondering...my car has siemens dekas, valve springs, centre muffler removed, f6 cooler and a custom headsex tune running about 12psi but I havent dynoed it yet as it was off the road for quite some time, what sort of power would you guess I would have? and if I was to fit a high flow cat, pw stage 1 cooler and maybe a walbro fuel pump what can I expect? Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/41115-how-much-power-should-i-have/ Share on other sites More sharing options...
Guest Wingnut Guests Posted 25/12/07 12:37 AM Share Posted 25/12/07 12:37 AM Random wild uneducated guess..... 280rwkw in current and 300+ after future mods.Good luck with it Link to comment https://www.fordxr6turbo.com/forum/topic/41115-how-much-power-should-i-have/#findComment-613688 Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 10m 11d Gender: Male Location: The 8th Dimension Posted 25/12/07 01:33 AM Share Posted 25/12/07 01:33 AM That sounds about right. Link to comment https://www.fordxr6turbo.com/forum/topic/41115-how-much-power-should-i-have/#findComment-613692 Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 18y 1m 20d Gender: Male Location: Canning Vale, W.A Posted 25/12/07 01:54 AM Share Posted 25/12/07 01:54 AM Without the Cat done you'll be restricted to the 270-280 mark mate.Once you've done that, with a decent I/C you'll get a nice consistent 300+ I'm guessing about 305-310rwkwWhat gear box are you running mate? Link to comment https://www.fordxr6turbo.com/forum/topic/41115-how-much-power-should-i-have/#findComment-613694 Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 19y 15d Gender: Male Posted 25/12/07 01:57 AM Share Posted 25/12/07 01:57 AM It could 250- 280GET IT ON A DYNO Link to comment https://www.fordxr6turbo.com/forum/topic/41115-how-much-power-should-i-have/#findComment-613695 Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 9m 8d Gender: Male Location: Melb Posted 25/12/07 02:15 AM Share Posted 25/12/07 02:15 AM currently you have approx 250rwkw... your power is limited because of your cat, you only have approx 9psi boost from memory with duty cycle of 1 (ie, cant command any more boost)..Changing the cat will give you approx 12psi boost, and give you the ability to get approx 270rwkw, and then with a good intercooler and a 12psi actuator, you should easy crack 300rwkw..valve springs will also need attention if you havent already changed them yet.. Link to comment https://www.fordxr6turbo.com/forum/topic/41115-how-much-power-should-i-have/#findComment-613698 Share on other sites More sharing options...
XRDOSE BIGRED Donating Members 1,410 Member For: 18y 1m 25d Gender: Male Location: Sth East Melb Posted 26/12/07 08:20 AM Author Share Posted 26/12/07 08:20 AM Without the Cat done you'll be restricted to the 270-280 mark mate.Once you've done that, with a decent I/C you'll get a nice consistent 300+ I'm guessing about 305-310rwkwWhat gear box are you running mate?its 4-speed auto. Might have to look at getting it toughened up if im hitting 300+ would u think? Link to comment https://www.fordxr6turbo.com/forum/topic/41115-how-much-power-should-i-have/#findComment-613845 Share on other sites More sharing options...
XRDOSE BIGRED Donating Members 1,410 Member For: 18y 1m 25d Gender: Male Location: Sth East Melb Posted 26/12/07 08:24 AM Author Share Posted 26/12/07 08:24 AM currently you have approx 250rwkw... your power is limited because of your cat, you only have approx 9psi boost from memory with duty cycle of 1 (ie, cant command any more boost)..Changing the cat will give you approx 12psi boost, and give you the ability to get approx 270rwkw, and then with a good intercooler and a 12psi actuator, you should easy crack 300rwkw..valve springs will also need attention if you havent already changed them yet..hey danny my car actually hits 15psi when I boot it then comes straight back down to 12psi and sits there that's all we could tune it to because of the cat and I also did the valve springs at nizpro before I took it to you, guess u cant remember every car u tune aye I definately will be getting the hi-flow cat after new years and we'll have to book it in at the dyno to see what shes really doing! CANT WAIT!! Link to comment https://www.fordxr6turbo.com/forum/topic/41115-how-much-power-should-i-have/#findComment-613847 Share on other sites More sharing options...
CJ_AK cj_ak Donating Members 5,077 Member For: 17y 10m 18d Gender: Male Location: Ropes Crossing Posted 26/12/07 10:54 AM Share Posted 26/12/07 10:54 AM Agree with xrdose.mine pulled 255.4 with a custom 10psi tune at C & V Link to comment https://www.fordxr6turbo.com/forum/topic/41115-how-much-power-should-i-have/#findComment-613882 Share on other sites More sharing options...
