  • Member For: 22y 24d
Posted
Its BB here using trough's account.
I was driving along and tunred through an intersection, halfway through the intersection the ute died, then started, then died... now its DEAD.
the EEC relay makes a funny buzzing noise, I have tried numerous relays in it but it continues to buzz. The fuel pump doesn't prime, it doesn't evan try and kick over. Have tried jump starting it but no go, the relay just continues to buzz.
need help... so much for getting a tune boxing day :(
BB
  • Replies 63
  • Mmmmm......BOOST
  • Member For: 19y 5m 4d
Posted (edited)
goin through the workshop manual for you now havn't found any thing yet
pm sent
Edited by our06t
  • Here since the start...
  • Legacy Donating Member
  • Member For: 23y 5m 6d
Posted
The relay isn't the problem then.
Is the 30amp engine fuse blown?
Posted
its got sumthing to do with the circuitry going to the relay, weve had the whole fuse panel lifted out and inspected underneath and all seems fine, no melted wires or burnt smells.
whenever ACC is on the relay just BUZZ's and vibrates.
whatever it is, its killing the entire engine managment cuz when ACC is on or when attempting to crank, the fuel pump wont prime or ANYTHING. even the starter motor wont click.
its disabled the entire engine managment.
the ABS gives a "click" every now and then when u press on the EEC relay...?
its a tricky one. RACV road-kill are coming later to TRY and fix it.... oh well a free tow to ford!
  • Member For: 22y 7m 18d
Posted
I bet your battery is FUBAR. Sounds like a cell or 2 have collapsed.
Posted
I would say the that buzz/vibrate the relay is doing is actually the relay rapidly opening and closing.
Posted
nope!
tried jumping it and also used a different battery. all multi-meter tests to battery and earths and also ECC relay are ok...
got us fooked
Posted
correct! that's how a relay works....
Posted
The fuel pump won't work because it's relay is triggered by the EEC relay.
Pull the HEGO fuse and try it.
