  • Member For: 19y 11m
Posted
Hi guys ive had a ongoing problem with the car coughin and spluttering and generally just a bit lazy . The problem is mainly when u are givin it a bit of stick from second to third (auto 4speed) I think it holds gear for a sec then seems to lose momentum for a sec u can hear it spluttering away then its fine. Ive had the car in to ford to check coils etc but they say there fine and couldnt really pin point it its only just started doing if after changing the centre muffler. Any ideas?
  • CNUTOX
  • Legacy Donating Member
  • Member For: 23y 8m 23d
Posted
Your cat could be fukt?
Posted
its basically standard only mods are typhoon cai and centre muffler its starting to frustrate me
  • www.australianflag.org.au
  • Member For: 21y 2m 12d
Posted
Mate the 2nd CAI will let more in, the centre muffler removal will free up the exhaust to a degree, the Cat should keep all this in check, but maybe for peace of mind put it on a dyno and get it checked out. If it is not the problem, then someone around the dyno may point you in the right direction.
Scotty
  • Mmmmm......BOOST
  • Member For: 19y 5m 1d
Posted
check plugs
clean throttle body
check all vacumm lines around the turbo
hope whoever did you muffler didn't arc something out maybe could have givin one of the electrical components a power surge
my auto holds 2 to 3rd when itno it but it's all but stuffed it also slips under heavy load in top gear
just some thoughts
Posted
yer I dont think its slippin it will change eventually then it feels like a n/a for a few secs makin a rough note like its in limp mode then its fine again but when u gradually ease on the throttle its fine
Posted
  • loitering with intent
  • Member For: 23y 1m 10d
Posted
don't know your whereabouts, but take it to one of the site sponsors. Wouldn't trust the
chimps at Fraud service to fetch morning tea
Posted
im in brisbane I was going to wait till I get and edit but I might just get it looked at for peace of mind where would you recommend ?
