November 24, 200718 yr #1 Hi can anyone help me with a problem that I am having...Ok I Need to know which wire is the ECU to Boost Control Soleniod Any help would be greatly appricated on this topic Thanks
November 24, 200718 yr #2 The C connector. The wiring is W-R from the PCM to solenoid and R-G out of the solenoid.
November 24, 200718 yr #3 Author I would want to play with the wastegate control soleniod that should be the one that I would hook up a Eboost too?
November 24, 200718 yr #5 Author The C connector. The wiring is W-R from the PCM to solenoid and R-G out of the solenoid.Any chance you could put that into stupid terms so we are talking about the wastegate solenoid under the fuse box right so I want to cut the W-R but what is W-R? thanks
November 24, 200718 yr #6 I don't have the coding but it's more than likely a White with Red traced wire.No offence, but if you need it in "stupid terms" should you be playing with it?
November 24, 200718 yr #7 Author Probley not but I will sure as hell try lol thanks for all your help with this one I will go and try now and see what happens.Thanks Again
November 24, 200718 yr #8 No idea.Eboost is trouble from what i've read.An Eboost is a great bit of gear with the right set up and tuningWoggy, why arent you using the solenoid thats supplied with the Eboost? if you disconnect the factory solenoid your ecu wont like it. You understand that you will need you edit tune adjusted to suit the boost level you want to run.
November 24, 200718 yr #9 Double check the wiring before you go hacking anything up. The last thing you want to do is cut the wrong wires. Who knows what could happen!
November 24, 200718 yr #10 Author I have designed up a simple pcb to alter to signals to ajust the boost without needing a tune so far with it installed and no flash tune I have managed to get 9psi without any problems and my afr gauge is showing that I am not leaning out yet so I think with a bit more development I should be able to get more but at the moment I am at my limits with what I have built And a big To the FORD ECU
