August 21, 200719 yr #1 Hi Folks,I bought a new remote of a goose on ebay and he forgot to send the instructions on how to programme it... does anybody have an idea on how to programme the keyless entry remotes?Ozzie
August 21, 200719 yr #3 It's in the manual dude To train keypadsOld keypads are removed from the system memory during thetraining procedure. Ensure all keypads are available to be retrainedat the same time (old and new).1. Switch the ignition from the OFF to the ACC position.2. Press the rear window demister button 3 times within 5 seconds.The door locks will cycle to indicate that the system is in trainingmode.3. Press any button on the keypad to be trained. The door locks willcycle to indicate that the keypad has been trained.The first keypad trained will result in one door lock cycle, thesecond keypad trained will result in two door lock cycles, etc.4. Repeat Step 3 for all other keypads to be trained.5. Turn the ignition OFF. The door locks will cycle to indicate that thetraining mode has been exited.EDIT: Bastard beat me to it Edited August 21, 200719 yr by tab
August 21, 200719 yr #4 Yes but Tab, as usual, you are thorough....You might be a little slow, but you come thru in the end, and that's all that matters!
August 21, 200719 yr #5 Except it is already coded and you cant decode one or half of QLD would have keypads to Tabs car!!!!!!!!1
August 21, 200719 yr #6 Just for the blind old geriatric fool:Old keypads are removed from the system memory during thetraining procedure. Ensure all keypads are available to be retrainedat the same time (old and new).Oh and thanks Mickus - I think
August 21, 200719 yr #7 Author Just for the blind old geriatric fool:Oh and thanks Mickus - I think Tab you the man!!Thanks for the help, all is well. Ozzie
September 4, 201214 yr #9 Ok guys have followed these steps and the car (2004 BA ) tries to lock then unlocks instantly and sound the horn as if a door is not shut properly. Have been all round the car and shut everything twice to make sure and still same results. I have reprogrammed the remote twice with same results.Any ideas or do I take it to Ford and pay the hefty price ? Edited September 4, 201214 yr by turbo proud
