  • Member For: 20y 7m 5d
Posted
Hey guys I know there is about 2 billion topics on this but I have read through them but am still confused as to what I need for this conversion. For starters I bought a mal wood built t56 second hand of someone and he was using the same yolk as he had in his 5 speed but in some of the posts they say u need a XR8 yolk true ?
Secondly I have had the clutch and flywheel sitting in a box for a while should I get my flywheel machined before I put it in ?
With the reverse lockout is there something I need to get from ford to hook this up or should it all be there ?
They are the main things I think I wanted to address, but if there is anything else I need to complete this conversion please let me know, as I have the t56, the cross member, the mal wood option 3.
Cheers,
Daniel
Also if there is anyone in Townsville that has done this, or is some kind of gearbox guru let me know, there will be some cartons in it :beerchug:
  • No V6 for me thanks!!
  • Legacy Donating Member
  • Member For: 21y 2m 6d
Posted
Hi Daniel,
This will help http://www.fordxr6turbo.com/forum/index.ph...c=15848&hl=
If there is anything else you may need to know Mal Wood will be the one to ring.
Being one of Mal's boxes he will know exactly what you need.
The reverse lock out in most cases we wired it to the brake lights.
Muzza.
