August 4, 200719 yr #1 Hi guys, Been browsing for a while and picking up a lot of useful ideas and tips. Finally worked out how to register ( wouldn't accept hotmail account) I own a 05 MK 11 BA T Ute. and up to recentlly have been pretty satisfied with the performance - CAPA + Custom tune + typhoon lower intake . Bug bit and thought I would go for a bit more power and went to Castle Hill Exhausts to get a s/s/hi flow catco cat then off to C&V who fitted siemens injectors and stronger valve springs then re-tuned. Unfortunately they could only get it up to 255 rwkw , Con thought that turbo gasket was broken which could cause it to be underpowered so I went home , removed heat shields let motor cool right down, restart motor and sprayed soapy water around flanged joint and sure enough- leaking. will get it sorted monday then give C&V a call to book her in for another attempt at squeezing a bit more power out. Realistically I thought that with these mods that I might be getting around 270 to 280 rwkw. Probably dont want to much more as it is only 4 speed auto. Anyway good to be finally on board. Cheers.
August 4, 200719 yr #2 Welcome Tig, You get use to the power and start looking for more, its a viscous circle. its great fun thou.....
August 4, 200719 yr #6 Welcome Tig, You get use to the power and start looking for more, its a viscous circle. its great fun thou.....So true..Welcome
August 4, 200719 yr #7 Welcome TIG.We've got similar mods (well actually most start with the same) and I've ended up with 278 RKw's.Like you I'm mindful of the 4 spd auto but didn't realise it was going to be an issue until after I had mods done.Am a bit suss on it now but take it easy most of the time until I can get some more cash together and strengthen the auto before some more mods. It's a disease I'm tellin' ya !!!Anyway Coops
August 5, 200719 yr #8 WelcomeFix up all those leaks and it will pull alot more power... exhaust manifold/turbo leaks are very common, get used to tightening all the bolts up lol
August 5, 200719 yr #9 Dont forget other things like brakes and suspension on the car as these will also add to the fun factor.and wellcome.I.B.
August 5, 200719 yr #10 Author Thanks for the warm welcome guys, looking forward to discussing some interesting topics.
