kilmo Donating Members 122 Member For: 17y 11m 15d Gender: Male Location: Perth, WA Posted 01/08/07 01:43 PM Share Posted 01/08/07 01:43 PM Hey guys, does anyone know what line I have to severe to install the T Join for my boost gauge ??? Link to comment https://www.fordxr6turbo.com/forum/topic/37125-boost-gauge-installation/ Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 7m 7d Gender: Male Location: Perth, NOR Posted 01/08/07 01:46 PM Share Posted 01/08/07 01:46 PM The thin hose which plugs into the top of the blow off valve. look at the blow off valve, there will be two hoses about an inch in diameter, dont touch those...at the top of the blow off valve will be a hose about 6mm in diameter, that's the hose. Link to comment https://www.fordxr6turbo.com/forum/topic/37125-boost-gauge-installation/#findComment-560386 Share on other sites More sharing options...
kilmo Donating Members 122 Member For: 17y 11m 15d Gender: Male Location: Perth, WA Posted 01/08/07 02:01 PM Author Share Posted 01/08/07 02:01 PM Cheers =) Link to comment https://www.fordxr6turbo.com/forum/topic/37125-boost-gauge-installation/#findComment-560388 Share on other sites More sharing options...
rhys86 Donating Members 443 Member For: 18y 5m 17d Gender: Male Location: Wollongong Posted 03/08/07 12:37 PM Share Posted 03/08/07 12:37 PM Cheers =)Just throw a 'T' piece in that 6mm hose and its done, piece of cake Link to comment https://www.fordxr6turbo.com/forum/topic/37125-boost-gauge-installation/#findComment-560897 Share on other sites More sharing options...
kilmo Donating Members 122 Member For: 17y 11m 15d Gender: Male Location: Perth, WA Posted 04/08/07 05:55 AM Author Share Posted 04/08/07 05:55 AM What is a usual vacuum pressure for at idle ????? I'm currently running about 0.6 Bar Link to comment https://www.fordxr6turbo.com/forum/topic/37125-boost-gauge-installation/#findComment-561025 Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 11m 9d Gender: Male Location: The 8th Dimension Posted 04/08/07 06:02 AM Share Posted 04/08/07 06:02 AM When warm mine sits at 18 Hg in. Link to comment https://www.fordxr6turbo.com/forum/topic/37125-boost-gauge-installation/#findComment-561026 Share on other sites More sharing options...
kilmo Donating Members 122 Member For: 17y 11m 15d Gender: Male Location: Perth, WA Posted 04/08/07 06:31 AM Author Share Posted 04/08/07 06:31 AM When warm mine sits at 18 Hg in.that's about 0.6 Bar so that's about right...... =) Phew.....I thought something may have been wrong Link to comment https://www.fordxr6turbo.com/forum/topic/37125-boost-gauge-installation/#findComment-561035 Share on other sites More sharing options...
J2Racing Member 70 Member For: 18y 2m 16d Posted 10/08/07 04:54 AM Share Posted 10/08/07 04:54 AM I know this is deviating very slightly off topic, but most people have said the easiest way to get power to light up the boost gauge is to run it off the traction control switch, so that when you flick the lights on, on comes the lights on the boost gauge, one problem, I got the premium sound with dual climate control, the traction control switch is waaay down just above the tissue box holder.Would it be easier for me to wire it to the foglamp switch, which is still in its normal location?any help would be appreciated guys Link to comment https://www.fordxr6turbo.com/forum/topic/37125-boost-gauge-installation/#findComment-563056 Share on other sites More sharing options...
rhys86 Donating Members 443 Member For: 18y 5m 17d Gender: Male Location: Wollongong Posted 10/08/07 05:19 AM Share Posted 10/08/07 05:19 AM I know this is deviating very slightly off topic, but most people have said the easiest way to get power to light up the boost gauge is to run it off the traction control switch, so that when you flick the lights on, on comes the lights on the boost gauge, one problem, I got the premium sound with dual climate control, the traction control switch is waaay down just above the tissue box holder.Would it be easier for me to wire it to the foglamp switch, which is still in its normal location?any help would be appreciated guysYou could run it of the fog light switch it much ofa muchness really. What ever one you think will be easiest for you to reach you should go with. I have mine wired to the t/c switch but that's because I found it easier to go go with th t/c switch. Link to comment https://www.fordxr6turbo.com/forum/topic/37125-boost-gauge-installation/#findComment-563068 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 1m 21d Gender: Male Location: Victoria Posted 10/08/07 06:29 AM Share Posted 10/08/07 06:29 AM The smokers pack light harness is also very easy to get to. Link to comment https://www.fordxr6turbo.com/forum/topic/37125-boost-gauge-installation/#findComment-563079 Share on other sites More sharing options...
