hqracer89 Donating Members 324 Member For: 17y 11m 15d Gender: Male Location: Ballarat Posted 20/07/07 08:37 AM Author Share Posted 20/07/07 08:37 AM Thanks for the heads up, I'm going to the footy tomorrow so, the first lot of testing can wait until Sunday. I'll try and get the photo up than too. Link to comment https://www.fordxr6turbo.com/forum/topic/36758-cooling-turbo/page/3/#findComment-556967 Share on other sites More sharing options...
ExAreSix TRAITOR Member 1,063 Member For: 22y 8m 3d Gender: Male Location: Townsville, NQ Posted 20/07/07 10:44 AM Share Posted 20/07/07 10:44 AM I don't know why you guys are all shooting this chap down for. He's sharing a modification that he is undertaking, that may or may not benefit us all. It sounds like a trivial thing, that won't make any difference. But geez, no need to be rude about it guys. Keep an open mind.Or are you 'old dogs' just not willing to accept that maybe someone else may do something different and introduce something new to the community, rather than yourselves??I do think that if you can bring the bearing temps down, it will also bring down the charge air temps. Will it be a measurable difference? I'm not sure...But with a top mount cooler, susceptible to heat soak, maybe Ford have increased the bearing cooling in the territory for a reason? That poor IC could use all the help it could get. Link to comment https://www.fordxr6turbo.com/forum/topic/36758-cooling-turbo/page/3/#findComment-557002 Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 11m 15d Gender: Male Location: The 8th Dimension Posted 20/07/07 11:04 AM Share Posted 20/07/07 11:04 AM Not Bagging him, Just think at standard or mid power levels is a bit early to be drilling holes in the turbo.Any way good luck with the mod, let us know how it goes. Link to comment https://www.fordxr6turbo.com/forum/topic/36758-cooling-turbo/page/3/#findComment-557006 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 5m 30d Gender: Male Location: Perth, WA Posted 20/07/07 11:27 AM Share Posted 20/07/07 11:27 AM (edited) sounds like a very nice car mate.I only reason I have started this tread is that I have been told by some one who I can not name, that this was a big down fall in the turbo design, and when the Territory's were being designed they were getting way too hot. These holes were made larger to cool the turbo more and this dropped the temp down in the engine bay.OK I'm not going to shoot you down here, but I do think you have been given bad advice, or have misunderstood what may or may not be achieved.Cooler engine bay - I think not!!! Stop and think about it for a second........ You have a small tube supplying only the centre of the turbo with a small amount of water, purely to keep the bearing housing below a temperature where the oil will carbonise, which would result in blocked bearing housing on the turbo, nothing more, nothing less.The small amount of water passing through the housing (even if you were able to increase the flow by 50%) will have absolutely no impact on engine bay temperature.The issue here is if the standard cooling system is doing its job, and with the right oil, the answer is yes, as we would have otherwise seen more failed turbos full of carbon in the bearing housing, something which is not the case.Will you achieve more water flow - possibly Will it make the temperature lower - Hmmmm yet to be convinced Will it have any impact on longevity of the turbo - Probably notHope this helps without offending I do agree that we should have an open mind to whatever people do, but also that some of the 'Modifications' discussed should be criticised if they are of doubtful benefit, as other members look to the forum for advice on useful things to do to their cars to increase performance or durability, and not all advice given passes either of those criteria. Edited 20/07/07 11:28 AM by Ninka Link to comment https://www.fordxr6turbo.com/forum/topic/36758-cooling-turbo/page/3/#findComment-557013 Share on other sites More sharing options...
F6 RAPID Formerly Turbo6 Donating Members 2,332 Member For: 22y 5m 14d Location: North Brisbane Posted 20/07/07 08:37 PM Share Posted 20/07/07 08:37 PM You won't cool the charge air with larger coolant holes - no way in gods green earth. The air flow is way too quick through the turbo and trust me, the coolant already flows through the turbo bloody fast! I learnt that the hard way when doing my turbo swap...............Not shooting you down at all but I would really focus your attentions elsewhere way before this mod for much better tangible results.Just trying to help! Link to comment https://www.fordxr6turbo.com/forum/topic/36758-cooling-turbo/page/3/#findComment-557072 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 1m 3d Gender: Male Location: Sydney NSW Posted 21/07/07 01:05 AM Share Posted 21/07/07 01:05 AM Yeah the water is just to cool the bearings/cartridge, not the housings... it would take ALOT of water to cool the housings lol Link to comment https://www.fordxr6turbo.com/forum/topic/36758-cooling-turbo/page/3/#findComment-557119 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 30d Gender: Male Location: Perth Posted 30/08/07 12:55 PM Share Posted 30/08/07 12:55 PM BUMPHow'd you go hqracer? did this mod set the xr6t world on fire?....... Link to comment https://www.fordxr6turbo.com/forum/topic/36758-cooling-turbo/page/3/#findComment-569765 Share on other sites More sharing options...
SCRIBR Yaris member Member 4,486 Member For: 19y 1d Gender: Male Posted 30/08/07 12:55 PM Share Posted 30/08/07 12:55 PM 2 weeks Link to comment https://www.fordxr6turbo.com/forum/topic/36758-cooling-turbo/page/3/#findComment-569768 Share on other sites More sharing options...
hqracer89 Donating Members 324 Member For: 17y 11m 15d Gender: Male Location: Ballarat Posted 04/10/07 08:52 AM Author Share Posted 04/10/07 08:52 AM Didn't get to do anything on this at all. I have lost the temp gun and they are not cheap to buy. Trying to think of another way to test. I was going to try and use a contact temp gauge but I don't think it will give a correct reading. I have now installed a Process West Stg 2 Cooler and had headsex to do the injectors and the tune.I think the best way to show that this may help any of us, is to get the temp of the Turbo before and after a hard run. But that's all I can think of at the moment Link to comment https://www.fordxr6turbo.com/forum/topic/36758-cooling-turbo/page/3/#findComment-581285 Share on other sites More sharing options...
