  • Member For: 19y 5m 8d
Posted
I recently purchased an xr6t which has had a suspension setup put under it by herrod. I had it in for a wheel alignment recently and the fella at the tyre shop told me it had 3 degrees too much camber on the right rear wheel and it was around 15mm lower. The question is: as this is not adjustable, will a camber kit solve this problem? The wheel aligner was unable to tell me as he dose not deal with aftermarket suspensions very often.
Any help would be much appreciated as 19 inch tyres aren't sheap :blink:
  • Member For: 21y 2m 25d
Posted
I have Herrod suspension in my car and the basic kit actually came with a K-mac camber kit, so you may have it actually fitted. If one of the springs is lower, the spring might be gone and needing replacing. Firstly though, take it to someone who does deal with aftermarket suspension and knows what they are looking at, least they may be able to point you in the right direction and also align the car properly once fixed.
  • some guy...
  • Member For: 23y 11m 24d
Posted
Geez, a wheel aligner who doesn't know much about aftermarket suspension setups? Good God! That's frightening.
Where are you located xhute?
  • Member For: 21y 11m 26d
Posted
:spoton:
I wouldn't be going back there again!
  • some guy...
Posted
I wouldn't even drive past the shop.
Look, although I'm a "qualified" wheel aligner, I am not a wheel aligner by trade so my knowledge of wheel alignments is ample but rudimentary. Even I know enough about BA suspension to not make such a call. The industry is full of monkeys...
  • Member For: 21y 1m 16d
Posted
Agree with the last sentence, plenty of zoos around, but finding competent and knowledgeable wheel aligners/suspension specialists is akin to finding good tuners -they are extremely hard to find.
Posted
Thanks for the replys. Guys. I ahven't been on the site long (as I haven't owned a turbo long) so any replies are good. But, and I have'nt had time to put it in my profile, I am at least 200ks from my nearest real city ( I am based in Bordertown) and by the guys own admission his job is to fit tyres, fix tractor and semi punctures (and as far as any of this goes I would swear by him, including basic wheel alignments), so having a shot at him is not entirely fair, after all he was honest, how often do you see that these days?
Anyway had a chat to the guys at beaurepairs a few miles away :roflmbo: and they reckon that a camber kit will rectify the problem.
Cheers again again for the replies
  • some guy...
Posted
Well, throwing money and patching things up will fix anything, yes, but cars just don't develop 3+ degrees of negative camber and drop a corner 15mm for no reason. There might be other underlying issues which may need fixing.
  • Bored Member
  • Administrator
  • Member For: 23y 10m 24d
Posted
Or it was like that since the fitting of the suspension and didnt have a camber kit fitted at the same time.....
  • Bored Member
  • Administrator
Posted
