  • Member For: 20y 4m 6d
Posted
started car up at lunch time to hear a familar clanking sound from car when starting, after I settled down from having a spastic attack I got under car to find flexplate loose, now I only fitted new flexplate a few weeks ago. this is the 2nd time it has happened in 500ks and it started since I fitted new convertor is this the problem or is the balancing on the motor causing the problem, motor is atomic with cams with 12ks I thought if it was the convertor it would come loose between convertor and flexplate not flexplate and crank
  • F6+300+
  • Member For: 21y 10m 24d
Posted
Had this on mine 4 times now so I now use lots of loctite and do them up FT.
New flex plate is @ $50 and a new set of bolts each time but the torque still seems to work them lose. Could be the ZF being in lockup so much they work the flex plate clockwise and anticlockwise more so than the old 4 speed.
Mine actually had no loctite on it from factory and I believe many years ago ford had a similar problem so they used loctite back then and now it’s a problem again as I know quite a few F6’s with this problem.
  • Member For: 20y 2m 27d
Posted
I blew mine off not long ago and the guys at CV bolted it back and then spot welded around the plate and since then no issues.
Posted
guy next door told me about spot welding it, I hadn,t heard of this before. would it be better if crank was dowelled.
  • No V6 for me thanks!!
  • Legacy Donating Member
  • Member For: 21y 1m 26d
Posted
A mate got his tuned a few weeks back then the flex plate come loose on his BF F6 3 days later. don'tthink it's linked but scared him anyway.
Muzza.
  • 1 month later...
  • Member For: 20y 8m 4d
Posted
I have had it happen twice now in 30000kms local ford dealer was kind enough to fix it for me second time around.
  • 3 weeks later...
  • Member For: 20y 9m 4d
Posted
mine came loose too and the blokes at morpowa spot welded it on and have had no probs since :spoton:
