J&SXR6T Member 56 Member For: 21y 3m 8d Posted 21/04/07 09:38 AM Posted 21/04/07 09:38 AM I was at the local ford dealer the other day and they had an xr6t that they where fitting a new engine too. I asked what had happened too the engine and the mechanic said the car had an after market intercooler fitted and as a result it over heated which blow the head gasket and then pumped water in too the cylinders casing the engine to hydraulic lock up which bent the rods and smashed a section off the block and bent some valves. No warranty because of the mod and a $13.000 bill to replace the engine.My question is do xr6t’s run hotter with a bigger front mount intercooler?could over heating cause so much damage.
Adam Here since the start... Legacy Donating Member 10,282 Member For: 23y 5m 2d Gender: Male Location: Victoria Posted 21/04/07 09:42 AM Posted 21/04/07 09:42 AM It makes sense in theory as you are covering up the radiator more, but my ute runs cooler with the aftermarket cooler than it did with the stock cooler on.$13,000 for a new engine! Is it gold plated?It must of been a major leak for it to put that much water into a cylinder.The whole story seems a bit far fetched to me.
J&SXR6T Member 56 Member For: 21y 3m 8d Posted 21/04/07 10:14 AM Author Posted 21/04/07 10:14 AM a mate and I grabbed the engine block out of the scrap bin all the other bits had to go back to ford. so I will get some pics of the block and the pice that broke off and put up soon.
mbjunior99 Member 4,359 Member For: 23y 9m 4d Gender: Male Location: Brisbane Posted 21/04/07 10:19 AM Posted 21/04/07 10:19 AM What cooler was it running??
xrdreaming Legacy Donating Member 1,693 Member For: 23y 7m 29d Gender: Male Location: Melbourne Posted 21/04/07 10:25 AM Posted 21/04/07 10:25 AM I am sure there was a hole in the block but there is no way that the bill for a new engine would be anywhere near $13,000, even from Ford, closer to around 6k if it needed head work done.My cooler is huge and 100mm thick too, the temp still sits under half way.
Adam Here since the start... Legacy Donating Member 10,282 Member For: 23y 5m 2d Gender: Male Location: Victoria Posted 21/04/07 01:54 PM Posted 21/04/07 01:54 PM a mate and I grabbed the engine block out of the scrap bin all the other bits had to go back to ford. so I will get some pics of the block and the pice that broke off and put up soon.I'm not saying the blown engine is a story, obviously it's true if the car was there getting a new one.It's just $13,000
SCRIBR Yaris member Member 4,486 Member For: 20y 3m 6d Gender: Male Posted 21/04/07 02:36 PM Posted 21/04/07 02:36 PM maybe it was an alloy block... an alloy of platium!
ALF05T Member 453 Member For: 19y 8m 13d Gender: Male Location: Sydney Posted 22/04/07 09:59 AM Posted 22/04/07 09:59 AM Nizpro do engines for $12500, ford always charge the earth for parts.The thermo fans play a part in keeping engine temps down so even if not enough air was getting to the radiator the thermos would supply cooling air once a threshold temp is reached. Correct me if I'm wrongCheers Alf
Fat-Tony Legacy Donating Member 5,364 Member For: 20y 6m 7d Posted 22/04/07 11:16 AM Posted 22/04/07 11:16 AM where was the guy driving around, in an African desert Story sounds a little far fetched to me, and so does the price of the engine replacement.
mbjunior99 Member 4,359 Member For: 23y 9m 4d Gender: Male Location: Brisbane Posted 22/04/07 11:18 AM Posted 22/04/07 11:18 AM It was ford service .... what would you expect?
