rednuts81 Get on the end of it..... Member 578 Member For: 20y 9m 13d Gender: Male Location: CQ Posted 01/04/07 07:43 AM Posted 01/04/07 07:43 AM Hi all ive just put in a wog cooler and the top pipe that gose under the head light looks like it is squashed a bit has any one had this problem, how to fix it besides smashing the head light out
rednuts81 Get on the end of it..... Member 578 Member For: 20y 9m 13d Gender: Male Location: CQ Posted 01/04/07 07:55 AM Author Posted 01/04/07 07:55 AM is there any pipeing kits for the wogcooler
ROLMDL role model Member 1,111 Member For: 20y 6m 19d Gender: Male Location: Melbourne,S.E Posted 01/04/07 08:54 AM Posted 01/04/07 08:54 AM is there any pipeing kits for the wogcoolergday rednuts I also have a wogcooler but I have no issue with the piping beeing squashedlooks normal to me mabye you should adjust the brackets and angle them abit and try and push the cooler to the left of the car away from the right headlight.its probly just the way the cooler been postion just play around with it and should come out allright
rednuts81 Get on the end of it..... Member 578 Member For: 20y 9m 13d Gender: Male Location: CQ Posted 01/04/07 09:00 AM Author Posted 01/04/07 09:00 AM gday rednuts I also have a wogcooler but I have no issue with the piping beeing squashedlooks normal to me mabye you should adjust the brackets and angle them abit and try and push the cooler to the left of the car away from the right headlight.its probly just the way the cooler been postion just play around with it and should come out allright yeh right o ill try that
Fat-Tony Legacy Donating Member 5,364 Member For: 20y 6m 9d Posted 01/04/07 12:06 PM Posted 01/04/07 12:06 PM installed these coolers a couple of times now, no issue with the squashing, you have not mounted it properly
bugster70 Legacy Donating Member 1,326 Member For: 21y 4m 27d Location: Canberra Posted 02/04/07 01:53 AM Posted 02/04/07 01:53 AM I'm pretty sure that all you need to do is rotate the hose a bit until it's not being squashed any more. Bit harder than it sounds as getting the stock hoses over the larger intake pipe of the Monza/Wogcooler is quite an art in itself!!!
Trough Lolly Member 4,349 Member For: 22y 21d Gender: Male Location: Mildura Posted 02/04/07 06:06 AM Posted 02/04/07 06:06 AM my ase cooler is very tight through the headlight area, its a tiny bit "ovaled" but I wouldnt say its restricted.
