jasonxr695 Member 51 Member For: 17y 8m 11d Gender: Male Location: New Zealand Posted 11/03/07 12:38 AM Share Posted 11/03/07 12:38 AM Hey all, just wondering, my turbo seems to using alot of anti-freeze is this normal and if not what would it be? Cheers Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 4d Gender: Male Location: Brisbane Posted 11/03/07 12:51 AM Share Posted 11/03/07 12:51 AM no - definately not normal.If there's no puddles on the garage floor I'd be getting the tranny oil checked ASAP (if auto). Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 21y 4m 5d Gender: Male Location: Perth, WA Posted 11/03/07 12:57 AM Share Posted 11/03/07 12:57 AM Also check your engine oil for comtamination, and it couold also end up in the combustion chamber if your head gasket is gone, but then your car should idle rough. Link to comment Share on other sites More sharing options...
dingah2 Crusty aviator Member 846 Member For: 19y 10m 10d Gender: Male Location: ACT Posted 11/03/07 07:26 AM Share Posted 11/03/07 07:26 AM ...or the auto transmission!Dingah Link to comment Share on other sites More sharing options...
mickq Member 740 Member For: 21y 7d Posted 11/03/07 01:42 PM Share Posted 11/03/07 01:42 PM My Mk1 XR6T used to use a bit....and it turns out there was some part related to the water pump that they ended up replacing (might have been a seal) - cant remember exactly what but it wasnt an uncommon problem.I had no sign of coolant on the ground or in the oil etc. Perhaps it leaked while I was flooring it.After that was fixed I never used a drop. On my Mk2 XR6T I have also never used a single drop. Link to comment Share on other sites More sharing options...
jasonxr695 Member 51 Member For: 17y 8m 11d Gender: Male Location: New Zealand Posted 11/03/07 07:49 PM Author Share Posted 11/03/07 07:49 PM Thanks,I'll get it checked out ASAP Link to comment Share on other sites More sharing options...
jasonxr695 Member 51 Member For: 17y 8m 11d Gender: Male Location: New Zealand Posted 13/03/07 08:02 PM Author Share Posted 13/03/07 08:02 PM Hi again,I have a 03 xr6t and I have just clocked 21k and it has been awesome apart from my coolant problem, I have read through the manual but nowhere does it say what coolant or any fluids for that matter that I should be using except windscreen washer fluid which since I topped up does not work all the best now, it just says to refer to the customer assistance, warranty and service guide which I do not have or did not get.Could someone give me a list of oil, coolant, brake fluid, diff oil etc I should be using for best performance,Thanks Link to comment Share on other sites More sharing options...
jasonxr695 Member 51 Member For: 17y 8m 11d Gender: Male Location: New Zealand Posted 13/03/07 08:37 PM Author Share Posted 13/03/07 08:37 PM oh and yes its Auto Link to comment Share on other sites More sharing options...
loopism Tractor Driver Member 709 Member For: 18y 2m 19d Gender: Male Location: Sydney Posted 13/03/07 11:30 PM Share Posted 13/03/07 11:30 PM Most oil companies will have a guide to what goes where. Check out the web site of Mobil, Castrol etc etc. Link to comment Share on other sites More sharing options...
