ExAreSix TRAITOR Member 1,063 Member For: 22y 6m 22d Gender: Male Location: Townsville, NQ Posted 24/01/07 07:47 AM Share Posted 24/01/07 07:47 AM Could be an overboost issue also. Right symptoms, and it is a MkI. But, not common in a stock car.Disconnect the battery overnight. Reset the PCM.Or even take it to Ford for a reflash with the latest code. Link to comment https://www.fordxr6turbo.com/forum/topic/32025-popping-noise-and-lost-of-power/page/2/#findComment-489752 Share on other sites More sharing options...
ROBiiE Donating Members 62 Member For: 21y 10m Location: Sydney Posted 24/01/07 07:54 AM Share Posted 24/01/07 07:54 AM I will try with the traction off but it does it in a straight line and has only started to do it.the popping is like the engine is missing or something←Check your spark plugs. I had a similar popping/missing sound a while back and a change of plugs fixed it. My T is modified but I assume the same issue can occur with a stock car. Good luck! Link to comment https://www.fordxr6turbo.com/forum/topic/32025-popping-noise-and-lost-of-power/page/2/#findComment-489755 Share on other sites More sharing options...
T007 Woooooooosh Donating Members 734 Member For: 19y 10m 4d Location: Sydney Posted 24/01/07 10:12 AM Share Posted 24/01/07 10:12 AM Traction control I would sayTyres ok or are they starting to wearIt was wet today as wellYou would be breaking traction often todayOr it could be something else Link to comment https://www.fordxr6turbo.com/forum/topic/32025-popping-noise-and-lost-of-power/page/2/#findComment-489846 Share on other sites More sharing options...
MR-XR Member 44 Member For: 18y 4m 21d Location: campbelltown,sydney Posted 24/01/07 10:31 AM Author Share Posted 24/01/07 10:31 AM I can understand what you r saying about the traction control but it only started to do it yesterday and it was dry wheather,I have had it since just b4 xmas it hasnt done it b4 that's why I think its a problem but then again im not sure that's why im asking you guys Link to comment https://www.fordxr6turbo.com/forum/topic/32025-popping-noise-and-lost-of-power/page/2/#findComment-489858 Share on other sites More sharing options...
XR64T Are we there yet? Donating Members 703 Member For: 21y 7m 11d Gender: Male Location: Sydney, NSW Posted 24/01/07 01:17 PM Share Posted 24/01/07 01:17 PM Definitely check the spark plugs but could be Boost Solenoid as well. Link to comment https://www.fordxr6turbo.com/forum/topic/32025-popping-noise-and-lost-of-power/page/2/#findComment-489976 Share on other sites More sharing options...
SMKY Member 4 Member For: 18y 8m 28d Posted 24/01/07 01:42 PM Share Posted 24/01/07 01:42 PM I have a BA XT with exhaust and it is doing the same thing. Started not long ago, going to change the spark plugs and see what happens. Link to comment https://www.fordxr6turbo.com/forum/topic/32025-popping-noise-and-lost-of-power/page/2/#findComment-489989 Share on other sites More sharing options...
Jjge New Member 6 Member For: 6y 6m 17d Posted 05/02/20 09:23 AM Share Posted 05/02/20 09:23 AM I’ve got the same problem . I’ve changed plugs, coils,turbo, cat, manifold gasket ,fuel filter the fuel pump and injectors we’re supposed to be fine too . It runs really rich in fuel is all I’ve got . So a retune is next at a tuner. Link to comment https://www.fordxr6turbo.com/forum/topic/32025-popping-noise-and-lost-of-power/page/2/#findComment-1692112 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,492 Member For: 17y 1m 1d Gender: Male Location: Melbourne Posted 05/02/20 09:36 AM Share Posted 05/02/20 09:36 AM Did you use aftermarket coils? Solid , too... 13ish years Link to comment https://www.fordxr6turbo.com/forum/topic/32025-popping-noise-and-lost-of-power/page/2/#findComment-1692113 Share on other sites More sharing options...
Jjge New Member 6 Member For: 6y 6m 17d Posted 05/02/20 06:39 PM Share Posted 05/02/20 06:39 PM Nah genuine ford Link to comment https://www.fordxr6turbo.com/forum/topic/32025-popping-noise-and-lost-of-power/page/2/#findComment-1692116 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,492 Member For: 17y 1m 1d Gender: Male Location: Melbourne Posted 05/02/20 11:29 PM Share Posted 05/02/20 11:29 PM Probably best to take it to an expert on these cars, then... It'll probably require a tune rather than mechanical fixes. Link to comment https://www.fordxr6turbo.com/forum/topic/32025-popping-noise-and-lost-of-power/page/2/#findComment-1692118 Share on other sites More sharing options...
